Funny. Yeah I detuned it. But all I had to work with was the SERT Race Tune that it had on it. Never said I was the brightest bulb in the box. All I know is now there's no knock retard.
It may be a good idea to refrain from using this word. It is likely to offend a millennial or two
Yea I never understood this either. My SV1000S is an 11:1 ratio & only requires 87. Maybe its the fact its water cooled?
I've run 89 octane in my 103 TC in the winter with no troubles but wouldn't do it mid summer. Can only get 91 octane here but thats always been adequate.
Wow, this turned into quite a conversation. While I understand engines, tuning, compression, and octane performance, I'm wondering why our "low performance" engines are so "hi-tech" they require high octane. From the various responses, I surmise that it's due to the "low-tech" (i.e., lack of sensors, cooling, etc.) paired with "high-performance" engineering whereas the high octane covers the lack of technology required. Thanks.
My Kawi ZRX took 87 octane. TheZZR1200 with the same bottom end with slightly higher compression, a better head, and different timing needed 91+ or it would ping
My current rice bike,a Kawi C14 is a premium fuel motor, very aggressive timing and fuel maps
Octane has zero to do with power, the guys running E85 are making sick HP with the right set up.
The Octane Rating is a numerical representation of the resistance to the stuff popping off without spark, aka pre-detination or pinging.
I can assure you when the gasoline mixture lights off before it is supposed to, it can destroy pistons, rods, bearings, cranks... you name it
I filled the C14 last night and premium fuel was almost 3 bucks a gallon, while 87 octane was in the 2.30 range.
That is the price of ownership, and an extra $4.00 a fill up is still cheaper than splitting the cases and replacing bent or melted parts.
All 3 of my bikes use premium fuel, as does the wife's Porsche,,, I know it costs more,,,, but it is still cheaper than the 100LL I have to buy when flying.... and the burn rate is about 10 gallons an hour... I flew in and out of Key West the other day and it was $6.80 a gallon and I needed 20 gallons.... do the math
Sorry dude. But, apparently you havent understood the other threads relative to octane & performance degradation to reduce knock. You should reread all the posts, and there will be a quiz at the end.
You must have me confused with another "dude." I never said anything about performance related to octane or knock. You should double check who you are quoting.
If the cost of running 91 Octane is too much for you - sell the internal combustion model and get a Live Wire.
Nope, as I said, I own two very new Harleys. It comes down to the actual REASON we need high octane when true performance bikes can get away with low octane. Either Harley can't engineer proper tuning for regular gasoline or they don't want to. The tech has been around since the 80s in the automotive world.
