Disabling security??
Old Apr 7, 2023 | 05:19 PM
barneyboy's Avatar
barneyboy
Originally Posted by Jehu
Guys, thank you all for the help.
Disconnecting some aftermarket stuff AND making absolutely sure that the bike was absolutely motionless and still did the trick! Prompt for PIN, entered PIN, good-to-go!
Re-attached everything, followed the above procedure (absolutely motionless) and good-to-go again.
You guys are all wonderful for jumping in with the help.
Much appreciated!
It's good to hear your issue has been resolved. Rounders to the rescue! Without his valuable technical input, there's no doubt in my mind the mystery would remain unresolved.
Old Apr 7, 2023 | 07:49 PM
Rounders's Avatar
Rounders
Originally Posted by FlamedFXR
You say 'I' more than et.
It may be because I have actually done it.
All this because I said zip codes work for code codes. Something easy to remember. Could have just said nothing, and I would never have commented again in this thread.
Old Apr 8, 2023 | 05:45 AM
Campy Roadie's Avatar
Campy Roadie
R&R the HFSM with a non security version, I did it to a 2011 RK and a 2002 Dyna (TSSM to TSM). Then I sold them to someone who wanted security on their bike. In both cases, I found a hack to get the bike to recognize the new, non security units (without going to the dealer). Once that was done, I had a bike that started with the key and no security. On the 2011, batteries seem to last longer without proximity security.
Old Apr 10, 2023 | 06:32 PM
Rustyg500's Avatar
Rustyg500
Much appreciated!
Jehu,
Which fixed the problem: 1 Disconnecting aftermarket parts of 2 Being absolutely motionless??
Old Apr 10, 2023 | 06:50 PM
Lawash's Avatar
Lawash
Stage I
Originally Posted by barneyboy
That procedure is for pre 2011. Your 2018 should automatically display ENTER PIN when you power up with the fob out of range.
just wondering if i was to put a new one on my bike do i have to take it to the dealer of could i do these steps as well?
Old Apr 11, 2023 | 05:56 AM
Jehu's Avatar
Jehu
Originally Posted by Rustyg500
Jehu,
Both, I think.
Everything is connected as per prior and, if the bike is absolutely motionless, it works!
Old Apr 11, 2023 | 06:52 AM
jake24lt's Avatar
jake24lt
Originally Posted by 702
If it's your 19 FXLR that's in your sig, yes it can be disabled. You either need the dealer do it with their scan tool, or I know it can be done with the TechnoResearch Centurion.
and Diag4Bike will as well.
Old Apr 13, 2023 | 08:09 AM
Reed's 1200's Avatar
Reed's 1200
6th Gear
My 2019 FLHTP has no security system, but I get the red indicator on the dash telling me there is a fault in the system, It comes on a minute or so after I start the bike. Can I disable it? I am mostly concerned it will somehow think it is being stolen and strand me.
Thanks
Old Apr 13, 2023 | 10:37 PM
skratch's Avatar
skratch
if the red light is staying on, check your trouble codes. i had one on recently, it was telling me that there was an open circuit in my right front speaker.
Old Apr 14, 2023 | 06:37 AM
Reed's 1200
6th Gear
Will do, Thanks
Dinky
Electrical/Lighting/Alarm
Apr 11, 2023 07:29 AM
GuitarKidd
Oct 9, 2018 06:55 PM
willshort
Sep 24, 2018 02:21 PM
ittu
General Topics/Tech Tips
Feb 16, 2013 01:38 AM
Blue Cross Bones
Jan 22, 2011 04:51 PM
