Softail slip onson a Dyna
Old Sep 6, 2007 | 05:30 PM
pairadice's Avatar
pairadice
Default Softail slip onson a Dyna
Okay, this may seem like a stupid question but I'm always trying to save a buck. Will SE slip ons from an 06 Softail fit my 07 Dyna SBin any way shape or form?
Old Sep 6, 2007 | 06:19 PM
Cynic's Avatar
Cynic
Default RE: Softail slip onson a Dyna
https://www.hdforums.com/m_1997179/tm.htm
See post #6........I guess you could also adapt the Softail arm. I looked at doing that, but the Softail arm looked cheesy to me and the brackets were easier to do. The muff with the little longer stub is the rear one. I forget how much I took off.
Old Sep 7, 2007 | 12:00 PM
pairadice's Avatar
pairadice
Thanks for the info. I can fab a couple of brackets tosave myself a few hundred bucks.
The pipes look good on your bike.
Old Sep 7, 2007 | 12:14 PM
Cynic's Avatar
Cynic
The pipes aren't on the bike, so if you need measurements let me know, But if you mount the pipes and the arm you can come up with your own angles and measurements. I used the least possible angleon the brackets. The screws are stainless carriage screws spotted to the bracket so they don't rotate. You can also use nylock nuts on them, they won't melt.
Old Sep 7, 2007 | 02:14 PM
pairadice's Avatar
pairadice
Thanks Cynic. Any dimensions would be great. My bro in Missouri is shipping the pipes out.
Pair-A-Dice
Old Sep 7, 2007 | 04:28 PM
Cynic's Avatar
Cynic
The slip-ons I used were for a 2000 later Softail # 80220-02 SEII+ . I don't know if the mounts will be the same on yours, do you know? If so, I'll send you a diagram with measurements and parts.
Old Sep 7, 2007 | 04:44 PM
pairadice's Avatar
pairadice
Cynic,
The part numbers are the same for the 2000 thru 2006 Softails. Should be a fit. Although I understand the SE II's are no longer available the mount should be the same.
Thanks,
Pair-A-Dice
Old Sep 7, 2007 | 04:50 PM
Cynic's Avatar
Cynic
OK, I'll dig out the exhaust and geteverything measured up for you, may take a day or two.
Old Sep 12, 2007 | 03:35 PM
Cynic's Avatar
Cynic
You have a PM
Old Sep 12, 2007 | 04:55 PM
pairadice's Avatar
pairadice
Cynic,
Thanks, got the PM. All the info for fabrication seems to be clearly defined. I will generate a drawing for both brackets with and without the bends. I'll probbly go with the bend for a cleaner look.
Thanks again for all your help, I do appreciate it!
Krazy8s
Feb 7, 2011 09:17 AM
chad pickens
Jun 22, 2010 11:26 PM
gremlin1
Jun 1, 2008 09:39 PM
pairadice
Sep 11, 2007 10:31 AM
