Please help Left blinker problem
Old Sep 15, 2007 | 11:00 PM
08 1200L's Avatar
08 1200L
Default Please help Left blinker problem
I have a 2008 1200L when I turn on the ignition switch my left blinker comes on and it want cancel out, unless I turn on my right blinker then the left want come back on, any suggestions? Thanks
Old Sep 16, 2007 | 12:22 AM
High Gear's Avatar
High Gear
Default RE: Please help Left blinker problem
I have no idea if this is your fix but the time I had blinker problems came from a fuse that had vibrated loose . It would make contact intermitantly , there was no rhyme or reason to how my signals would behave .
Old Sep 16, 2007 | 09:48 AM
08 1200L's Avatar
08 1200L
Thanks for the info I will check it out Hopefully it is not nothing major I like being safe
Old Sep 16, 2007 | 11:31 AM
Tinkermc's Avatar
Tinkermc
you have a short
Old Sep 16, 2007 | 12:05 PM
Johnny Law's Avatar
Johnny Law
On my 07 UC I had a simular problem. It turned out to be a left turn signal switch that was defective. My dealer has seen this a few times.They say it is either the switch or module.
Let us know what fixes it.
JL
Old Sep 16, 2007 | 12:08 PM
Yellotang's Avatar
Yellotang
Also itmay be moisture. After washing my bike sometimes I get this problem.
[align=left] [/align]
Old Sep 16, 2007 | 12:18 PM
Matrix's Avatar
Matrix
It sounds like the turn signal switch is your problem wether it is a short, pinched wire or a bad contact inside the switch it will have to be taken apart to tell for sure.
Old Sep 16, 2007 | 01:10 PM
PsycleFreak's Avatar
PsycleFreak
Here was my story:
When I turned the ignition on and my leftturn signals flash. I couldnt cancel it with the left button, but I could with the right.Once cancelled,I tried to turn the left signals on and nothing.
I could get the hazzards to work by just holding the right turn signal button in for a second. Then I could cancel the hazzards with just the right button.The only way I could get the left signals to flash at allis to hold the right signal button in (hazards)or turn on the ignition.
It ended up being the left turn signal switch (button). Also a friend of mine had the same thing happen also.............left side. Many stories of left side going out......wonder why?? Do we turn left more than right??
08?? Should be under warrenty, let the dealers mess with it.
JDH1929
Electrical/Lighting/Alarm
Dec 1, 2019 04:20 PM
OLDBOY98
Oct 5, 2012 09:50 PM
elizer
Jul 21, 2010 07:46 AM
gilly.0038
Jun 8, 2009 08:26 PM
ultra2006
Apr 22, 2007 12:55 PM
