Help approaching possible warranty issue.
I know that the fuelsensors has been an issue, and their head mechanic told me they have replace every one of them on the07's that they sold. So if they are fixingall of thefuel sensors, why not the brake calipers if allof them are doing it. Seems to me he is trying to smoke one by me. What can I do?
Thanks,
Woody
I took my 07 VRSCAW in afew months ago for a laundry list of things I'd like the dealer to fix under warranty. Odometer switch, leaking brake and clutch masters, inaccurate fuel sensor, and the rear brake caliper. Everything was fixed no problem except the rear caliper. The problem is the metal screen on the Brembo brakes was apparently loose enough to vibrate deep grooves into the caliper. Looking at the screen, its cracked, and the caliper is scarred. Service writer states that all V-rods do it, and HD will not warranty it. My front brake is exactly the same, and it does not have a mark on it. I intend to ask him to provide the written refusal that HD will not warranty.
Thanks,
Woody
The same kind of situation happened to me over the summer - I had a repair I thought should have been covered, but it was refused - and I got them (HD) to cover it. You can do a search in the forums for my thread: Spoked wheel fails. Long story short - The spokes failed on my rear wheel and the dealer said that HD refused to cover the repair/replacement. I found out that - once a month - HD holds a 'policy review' meeting that you can present a case for them to make an exception to their policies. I had the dealer file the necessary paperwork and I called the main office and e-mailed a letter explaining my reasoning. They - HD - ended up changing their mind based on my argument and covered everything.
I had to pay for the new wheel and mounting since I wanted my bike back ASAP, but I ended up getting a credit for the entire job. Of course, I spent the credit on a bunch of stuff I didn't really need...
Good Luck, Don
Ask them if they will fix your head after you hit a car when the brakes fail?
Its a safety issue.
Discuss it civily with the service manager or take it somewhere else.
I think they have to fix it.
MikeM
I appreciate the efforts.
Drich57, If you have contact info I'd be all ears.
Woody
Thanks,
Woody
I had an issue with my 07 Classic. Three of the sprocket bolts backed out after 5,000 miles and caused some extensive damage. They wound up doing more than I expected to regarding the repair. Harley was not going to cover the swing arm because they said it was just scratched and could have been touched up but my dealer replaced it as well as the wheel and sprocket. Like Punisher said they know your going to spend it anyway. I wound up spending a boat load of money while I was there on 5K service and I put on a race tuner kit. I would talk to the service manager and if I get satisfaction I would than talk with the owner of the dealership. Good luck..
