Rubber mount vs solid mount engines
When I first went looking for a Harley, one of the things about softails that turned me off was that they don't vibrate at idle. I grew up watching old timers on vibrating Harleys with that sweet sound, and I got that impression of a Harley etched in my soul. I'd like to own a softail if only they could get them to vibrate more.
The other thing I don't understand is why the Heritage comes with bags. They cover up the hardtail look, which is the whole point of the softail. The other thing that confuses me is why someone would add chrome covers like Kurys to the swingarm. IMO you should be able to see the continuous line of the swingarm without any added bling.
Number 1 Counterbalancing consists of a different crank ( Heavier crank than the A motors)
Number 2 More weight less power (thats why the B motors are in the soft tails not the touring bikes)
Number 3 Centrifigal force makes the B motors buzz thru the the floorboards due to the heavier crank
Number 4 A motors shake at idle , B motors dont
Number 5 As for The post that mentioned rubber mounted engines get more power to the ground how come MOROSO and tons of drag racers all run SOLID
mounted motors?
Number 6 Come to the table with some knowledge
See the irony in your knowledge comment?
The quote regarded rubber vs. solid mounted to get the power to the ground and stay in place
I have owned 5 V8 Vegas I know torque
As for counterbalancing small blocks the 400 small block was so countered balanced it was EXTERNALLY balanced same with the 383 stroker motors
A Dyna could handel a rigid-mounted TC96 A, just 95% of the folks who ride wouldn't enjoy it. The TCA still makes more power than the B... That was your #5 question, you didn't take about neither.
Now, my bike has both a rubber-mount and a counter-balancers, and puts out allot more power than either of those, pushing 165hp... (not stock), 120hp when it was basically sock.
And for drag bikes, depends what you are talking about, the Distroyer is like mine, has both, some of the really short stroke 4bangers are rigid...
mounted motors?
Whiffleboy
