Air Ride Rear Suspension v.s. Spring Shocks
Old May 19, 2009 | 08:27 PM
Fire Guys Road King's Avatar
Fire Guys Road King
Default Air Ride Rear Suspension v.s. Spring Shocks
OK, so I've got a new 09 RK and I'm not very impressed with the rear air ride. I had it at 0 by myself and would slowly add 5psi each time to get a sweet spot. NO matter where its set I still eat my *** on bumps! Who changed theirs to regular spring shocks like progressives or something?
Old May 19, 2009 | 09:14 PM
Lowridin packer's Avatar
Lowridin packer
You are way off, that is why. Set it at 30 PSI to start, not 0.. Then add 5 psi until it is good. You need at least 30. At 30 PSI, it will ride like a caddy. As an alternative, try reading your manual. ;-)
Old May 19, 2009 | 09:50 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Man, for a "Cheesehead", you shur gots a lot o' scooterz in yur grudge!!!!!
(AND a li'l 'feisty', too. )
Me thinx the Packer Backer is onto something, Fire Guy.
I run 16 -18#s in my rear 'shock'. (But you might jus' call it a 'tire' ) IF I put 30#s in it, and hit a pothole, can you say "airborne".
Old May 20, 2009 | 02:34 PM
danmo's Avatar
danmo
Did ya read your owner's manual? It gives guidlines on where to have them set at.
I'll never go back to spring shocks again, air ride all the way.
...well for a barhopper I'd put on spring shocks, but no long rides.
Old May 20, 2009 | 02:50 PM
barjbar's Avatar
barjbar
I think mine are at about 12 on my RK. I used to adjust them to about 22 if my wife was going with me but zero is the softest ride. I find it too wallowy (is that a word?). Bike just doesn't corner well. Twelve seems fine. I haven't been on any Harley with standard shocks that has a better ride so even if it's possible, I think you'd regret it. Big bumps you have to take your butt off the seat and use your knees as shock absorbers before hitting it even with a tourer. When I had my Sporster, my knees WERE the shock absorbers over all bumps.
89FLHTC
EVO
Feb 26, 2016 05:47 AM
68beep
2014-2024 Touring Models
May 11, 2014 01:29 PM
Tangle Eye
32
Jun 9, 2013 07:10 PM
shrekofd
Apr 15, 2013 02:53 PM
oilhog
Apr 7, 2008 09:18 PM
