beating a dead horse... sorry
Old Sep 1, 2009 | 12:18 PM
scampman_73's Avatar
scampman_73
Default beating a dead horse... sorry
i just used a hole saw and drilled the baffles out of my stock exhaust. i pulled out all the fiberglass and have put on probably 6 miles. its loud as all hell, and damn near annoying, i was just wondering if its safe to run it like this till i can get some cash scraped up to put on actual exhaust? sorry to enter a new thread that is the same as so many before, but i can't seem to figure out the search function. oh, by the way, i have a stock air intake, and no tuner. thanks in advance.
brian
Old Sep 1, 2009 | 12:25 PM
mp's Avatar
mp
You should be able to find some steel baffles for the stock mufflers. Google is your friend.
Old Sep 1, 2009 | 12:37 PM
RCB's Avatar
RCB
You will more than likely loose some low end torque.
Old Sep 1, 2009 | 12:42 PM
scampman_73
ok, i just wanted to make sure i wasn't going to burn up any valves running with out much back pressure. thanks for the nod on steel baffles, i might just look into that.
Old Sep 1, 2009 | 12:46 PM
Geoff's Avatar
Geoff
This won't hurt anything besides your neighbors' ears. Also, your riding partners might ask you to move to the rear.
Old Sep 1, 2009 | 12:49 PM
bdavis385's Avatar
bdavis385
I beg to differ. You may cause damage and you ought to at least check you spark plugs for a while to make sure you are not running too lean. I know that people say the stock ECM can make adjustments, I know people say that the A/C is restrictive and won't flow enough air -- but those people are not going to pay if there is trouble. The air flow can and will change (at least slightly) do to freer exhaust. Check to be safe and not sorry.
Old Sep 1, 2009 | 01:02 PM
FastHoss's Avatar
FastHoss
This is serious and could result in injury or death!
Old Sep 1, 2009 | 01:44 PM
2ForTheRoad's Avatar
2ForTheRoad
brian
So you drilled out the baffles and removed all the packing and it's annoying huh? Imagine that
I understand it won't hurt your bike, just everyone who has to listen to it.
Old Sep 1, 2009 | 01:49 PM
oct1949's Avatar
oct1949
brian
Every one that I know that has done this has been sorry afterwards..
People just don't believe how lousy they will sound. Plus mess up a set of stock pipes..
Keep an eye on Ur plugs that they aren't too lean.
The rule of thumb is pipes only change, needs no other work.
But U probably lost some bottom end by doing away with Ur backpressure..
Old Sep 1, 2009 | 01:56 PM
Ironbarr's Avatar
Ironbarr
Flashing red/blue lights and eerie, wailing sounds? Hmmmm.
