In response to wolf 1340, here's my dyno-chart. I had Jamie at fuelmoto install the cams and dyno it for me, and I'm very happy with the numbers with my Heavy Breather and true dual system. These numbers are as good or better than most 103 builds that didn't have headwork done. I have no reservations about using the Heavy Breather.
I do agree. Those are great numbers. What exhaust are you running? Which cams? I'll post mine when I get home.
Have one.
Bike will sound different when roll throttle on hard, if you old enough remeber how you Chevy sounded with air cleaner off just not as loud.
You will notice a slightly better..quick throttle responce.
Add some fuel and it gets better.
IMO of me the SE heavy breather was a good move
I have a Heavy Breather and SE Street Performance Slip-ons. Installed a PCV when I upgraded to the Heavy Breather. Can't tell yet if it's better or same. Not sure if I have the best map for the PCV - any suggestions?
Heavy Breather?- sounds like one but the noise dosen't result in more power - however, it's just part of the process of improving things. Speaking of which, the only way to get decent power (with a 96) is to port the heads, fit bigger inlet valves and stronger low mass springs, increase the comp ratio and select a cam to suit (for fast road work, high speed cruising, strong acceleration in the lower rev range etc) forget the SE EM device and fit something like a Power Commander. Get even more power and torque with a capacity increase, tuned length 2 into one exhaust system. Beyond this and you're into serious cash....
