speedo cutting out
Old Oct 19, 2010 | 05:23 PM
waterbuffalo750's Avatar
waterbuffalo750
Default speedo cutting out
ok, so the speedo and odometer keep cutting out on my 99 NightTrain. When the bike is at a low idle, my odometer is displayed, and both work up to about 10mph. If I rev the engine at all or go faster than 10, but the speedo and the odometer cut out. The light still works, but thats all. The onboard speedo diagnostic says "speedometer power overvoltage." I assume I have a bad voltage regulator. I just wanted some opinions before I pull the trigger on the regulator. Thanks!
Old Oct 19, 2010 | 05:32 PM
FlamedFXR's Avatar
FlamedFXR
Whew...I thought this might be worse than an assless chaps thread.
Old Oct 19, 2010 | 06:29 PM
geezer glide 56's Avatar
geezer glide 56
It is a real good chance that it is your regulator...The speedometer does that to protect from over voltage.
Old Oct 20, 2010 | 08:34 PM
harleydavis's Avatar
harleydavis
I had the same issue. The voltage regulator will cause the speedometer to cut out around 10 miles per hour. Replace the voltage regulator and the problem should go away. Check the voltage at the battery when the bike is idling with a digital multimeter. It should be around 12.7 volts. Now increase the rpm's and if the voltage goes above 14.3-14.7 volts then the regulator needs to be replaced.
RosevilleRiding
Jun 2, 2018 08:47 PM
chriswillrise
Nov 13, 2016 04:27 PM
the blob
Jun 11, 2016 11:44 PM
sinolav
Electrical/Lighting/Alarm
Jul 16, 2015 07:31 PM
BIGDADI
Apr 7, 2012 10:13 PM
