Tubes
Old Nov 20, 2010 | 01:01 PM
EJ48's Avatar
EJ48
Default Tubes
how often do you change your tubes? i'm putting new tires on this winter.
Old Nov 20, 2010 | 01:19 PM
WRAITH's Avatar
WRAITH
I use the tube for 2 tires, unless there is signs of wear. Replace the rubber band (spoke protector) every time.
Old Nov 20, 2010 | 02:26 PM
1SickNightTrain's Avatar
1SickNightTrain
I replace everything each time, (spoke protector, tube, along with the tire) It only cost 20-30 bucks extra and is worth the piece of mind.
Old Nov 20, 2010 | 07:07 PM
oldairboater's Avatar
oldairboater
Unless you are doing your own tire change out, most shops will not replace tubed tires without new tubes. Especially HD dealerships.
Old Nov 20, 2010 | 07:41 PM
deadman77's Avatar
deadman77
I now have tubeless, but I would say new tires, new tubes. Why would you not?
Its not worth the risk.
Old Nov 20, 2010 | 07:42 PM
bronxbill's Avatar
bronxbill
If you change the tire, change the tube and rim strip
Old Nov 20, 2010 | 07:52 PM
charle's Avatar
charle
Yep .
Old Nov 20, 2010 | 08:32 PM
mattkenzie's Avatar
mattkenzie
Change 'em.
Old Nov 20, 2010 | 10:13 PM
oct1949's Avatar
oct1949
Dealer will do it every time...
My Indy every two or three rears cause I go through more than 1 a yr.. front every other tire.
Iron lHorse
Sep 8, 2017 09:44 PM
k&j eglide
Apr 30, 2010 02:05 AM
gipsl67
Aug 2, 2009 06:04 PM
trip20
Wheels/Tires
Feb 18, 2009 08:44 PM
Square Dude
Jul 27, 2006 01:55 PM
