Change tubes with tires?
Old Feb 17, 2009 | 10:17 PM
trip20's Avatar
trip20
Default Change tubes with tires?
With spoked wheels using tire/tube combination, do you have to change the tubes when you change the tires, or are the tubes reusable?
... yeah you can make fun of me now ...
Old Feb 18, 2009 | 02:53 AM
xxxflhrci's Avatar
xxxflhrci
You don't have to. Many people don't. I always do.
Old Feb 18, 2009 | 08:45 AM
Prog Rocker's Avatar
Prog Rocker
Exclamation Nope...and here's why...
No, not going to make fun of ya...at least this time...!
It is not recommended that tubes be reused. The reason is simple: the tubes flex (and therefore heat up) at the same rate as your tire sidewalls do while riding. The tubes are not designed to do this forever, it just isn't physically possible. Reusing the tube means that you have a tire that has flexed far less than the tube has. The tube has therefore experienced more stress from the constant flexing over a longer period of time. Sooner or later, the tube will fail , and you will be S.O.L., as tubes also cannot be repaired.
I hope that this helps!
Cheers
Old Feb 18, 2009 | 08:46 AM
anubisss's Avatar
anubisss
Tubes are cheap. Change them.
Old Feb 18, 2009 | 03:54 PM
rbabos's Avatar
rbabos
Plus, as they get older with internal rubbing they won't hold air as well as when they were new. Really thin membrane compared to tubless tire.
Ron
Old Feb 18, 2009 | 08:44 PM
trip20's Avatar
trip20
Thanks guys.
It wasn't an issue of cash. I honestly didn't know how often one should replace the tubes. I just put so much focus on looking for a deal on tires that I hit me recently that I may need tubes as well.
Even if it isn't necessary, for the peace of mind it's worth it.
Thanks again.
s.ga.rider
Aug 20, 2011 06:25 PM
GLACIERPEARL
Mar 21, 2011 02:57 PM
EJ48
Nov 20, 2010 10:13 PM
skdvr
Oct 15, 2010 10:26 AM
gipsl67
Aug 2, 2009 06:04 PM
