soft tie downs
Old Apr 19, 2011 | 07:45 PM
rydahog's Avatar
rydahog
Default soft tie downs
i want to get 2 of these SOFT tie downs that go around your handle bars when you transport your bike with ratchet or pull tight nylon ties..where can i get this item..not sure how better to explain this..the part that wraps around handle bars is not nylon but covered in soft material to prevent damage to chrome..thanks
Old Apr 19, 2011 | 07:50 PM
Hx3's Avatar
Hx3
I got mine from my local Harley dealer, but I wouldn't recommend putting them around your handlebars. Harley handlebars tend to move when you tighten these around them. Ask me how I know....
Old Apr 19, 2011 | 07:53 PM
wilburz's Avatar
wilburz
why not take the existing nylon tie down with the hook on one end, pull the hook 2 feet over the handlebar, down to the other end, now wrap the tie down around the hook 4 times and pull down tight. now you have a large loop around your handlebars and nothing touching them except tie down strap. tighten the ratchet and your good to go. This is how I tie down my front end when I put it in the back of my truck.
Old Apr 19, 2011 | 07:57 PM
Deucedog's Avatar
Deucedog
Cycle Gear, and most dirt bike shops have them. I've seen them in Harbor Freight as well.
X3 has a good point. Many handlebars are mounted with rubber dampeners in the risers/trees.
You can damage, or even split, them if you put too much tension on them when tightening the straps.
I use the soft ties front and rear on the few times that I trailer my bike.
Old Apr 19, 2011 | 08:57 PM
Stickman81's Avatar
Stickman81
I have limited experience with this but...
I did do the tie a loop in the strap and hook it to itself and it works fine.
I wanted some of the straps and had seen some at Walmart but did not get them.
I went back later for them and they were gone. I looked other places as well.
I ended up getting one of three different models from the local HD store.
Old Apr 19, 2011 | 09:43 PM
BassCatcher's Avatar
BassCatcher
I've seen them in some auto parts stores, you might check around.
Old Apr 19, 2011 | 10:05 PM
46u's Avatar
46u
The only way I know to transport a motorcycle is to ride it unless it has a flat tire. The only time I use soft ties is when I am putting one on the lift to work on it.
Old Apr 19, 2011 | 10:26 PM
razorback84's Avatar
razorback84
Sometimes you just can't ride... It hurts, but I'm about to trailer mine across country when I move from Cali to Arkansas in 2 weeks.
X3 on not using the handlebars
Old Apr 19, 2011 | 11:31 PM
JaronB's Avatar
JaronB
I use these from Home Depot with built in soft ties. 1000 lb working load limit each and you get 2 for just over $20
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old Apr 20, 2011 | 12:26 AM
Andjh123's Avatar
Andjh123
x4, find somewhere around the triple tree/fork clamps or the frame to tie it down. Using the handlebars just makes them all crooked, possibly bent and messes up the risers and bushings.
