Harley key cost
Old Aug 17, 2011 | 07:13 PM
edteach's Avatar
edteach
Default Harley key cost
I was surprised to see that keys at the dealer were 35 dollars and I had to take in my title. LOL I thought they would also ask for a urine sample to go with it. I took the key [and I bet most of you know this, but I will post it anyway for those like me who don't] to a local key shop and it was 3.50 for a key that worked fine. Harley uses a vending machine type of key. For that I had a couple made and had 28 dollars left for gas. LOL. And I did not have to give a urine sample.
Old Aug 17, 2011 | 07:35 PM
skratch's Avatar
skratch
if you happen to be in an area where you can't get that type of key. you can always order the tourpak lock set. if you pull back the plastic cover on your key, there is a code. use that code when ordering the lock set. you will get a lock (obviously) and two keys, that match your existing keys. all this for around $20.00.
if you've lost both your keys, but have the number, you can do the same thing (my bike came with a little tag that has the number on it if i need to replace a key).
Old Aug 17, 2011 | 07:39 PM
brenn's Avatar
brenn
I took mine to a local lock shop too.
If you want real HD key blanks, (at least the tubular keys for softails) you can buy the replacement tubular key lock for a softail toolbox, for about $7, and it comes with 2 blank keys just like my ignition/fork key. Any softail key or key blank works in the tool box lock, so they still open that after they are cut for the ignition.
Old Aug 17, 2011 | 07:56 PM
schumacher's Avatar
schumacher
I need to get another one made, my dyna only came with one
Old Aug 17, 2011 | 08:15 PM
Uncle G.'s Avatar
Uncle G.
Heck, I bought an entire new ignition switch with two keys for my Softail from J & P for only $27. It's a better switch than the OEM unit, too.
Old Aug 17, 2011 | 08:35 PM
Ron750's Avatar
Ron750
I bought 2 spares for $24, from the dealer. They don't work smoothly on my saddlebags, tour pak. When I called the dealer they said, I must have ordered the wrong ones, but they have the same exact codes, stamped on the keys. They had no answer. Whatever?
Old Aug 18, 2011 | 08:37 AM
BillM's Avatar
BillM
I have seen my local dealer just hand them the key and say, "No charge"
Old Aug 18, 2011 | 08:52 AM
edteach's Avatar
edteach
I have not seen your dealer. LOL The two dealers I have delt with Wichita Alfes wanted 30 for two keys and I had to wait two weeks and give them my title. The other Worth in KC would not give me a quote on a bike they had listed over the phone unless I put a one thousand dollar deposit on it first. LOL So far the dealers I have dealt with are a bit snobby. But thats why after market parts and shops exist. LOL
Old Aug 18, 2011 | 11:34 AM
Robin A's Avatar
Robin A
24 bucks for 2 keys 2 weeks ago,still waitin'.......................
Robin
Old Aug 19, 2011 | 08:41 AM
winchcable's Avatar
winchcable
Default Part number?
Do you have a part number for this? I am having a hard time finding one.
Cbb129
Nov 14, 2021 12:35 PM
Pulchritude
Oct 21, 2012 08:39 PM
Pinebro
Jan 11, 2012 12:43 PM
Ultra-Snazzy
Dec 29, 2010 08:27 AM
gels55
Dec 11, 2007 10:45 PM
