Complaint
If that is what Harley told me to do, when I specifically told them about not riding it for long periods, then I would have done it. Instead, I did what Harley said, put it on a tender which lit up, started charging, and I walked away.
I guarantee the instructions tell you the indicator will switch to green when the battery is charged and that if it doesn't change, there's a trouble shooting guide. YOU assumed it was charging and it wasn't. Why is that a HD defect?
You brought it in before and they "fixed" it? What exactly did they do to it? Did they give you paperwork saying what was done? If so, pull the paperwork out and let us know what was done. If not, call the dealer and ask them.
You said you are 150 miles from the dealer so hopefully there is an auto parts store closer to you. After the battery is charged take it to an auto parts store. Most will have a battery tester that does a load charge. That will tell you if the battery is junk or not.
If the battery is bad I'd just buy one from any aftermarket supplier. Your local parts store may even have one. You don't need and HD branded battery.
Did you check the tender pigtail to make sure it was connected to the battery properly? The dealer installed it but they could have F'd it up.
If the connections are correct I would remove them and plug in the tender to the battery on the bench. Then check the lights for correct operation. Also, put a volt meter on the battery while the tender is connected to see if it's charging.
I know stuff like this can be frustrating but at least it f'd up while in your garage. I've had to do plenty of repairs while in the middle of no where or in bad weather.
RED FLASHING - When the red light is flashing, the AC power is applied to the charger and the microprocessor circuitry is functioning properly. There is no battery connected or there is a problem with the connections between the charger and the battery.
RED - When the red light is on, the battery charger is in the process of fully charging the battery. In order to properly charge large capacity batteries, the charger may remain in this mode for several hours or even days.
APPLICATION INFORMATION
Always operate the charger in a well ventilated area If neither indicator light comes on after you plug in the AC cord, then check the AC power receptacle. If the green indicator light comes on too soon, check the battery and the output connections from the charger.
GREEN FLASHING - When the green light is flashing, and the red light is on, the battery is greater than 80% charged and may be removed from the charger and used if necessary. Leave the battery on charge until the green light is solid whenever possible. Once the green light begins to flash, it will remain flashing until the battery charger output current drops below the optimum recharge threshold, or until the absorption timer expires.
GREEN - When the green light is lit, the battery charger is in the storage mode of charge. In this mode the charger will maintain the battery at full charge.
RED & GREEN ALTERNATING - This will indicate either a reverse polarity connection where the charger output cables connect to the battery, a sulfated batttery, a corroded battery terminal, or other high resistance output connection..
Having learned that batteries draw down when not used, I also figured, incorrectly as it turns out, that the tender would periodically charge (i.e. the light would go from green to red) when the battery went down, and then go green again when charged again.
In an attempt to prove to myself that I do have a life I am leaving this puppy as it meanders through cyber-space without me.
Hope all turns out well!!!
Sammi
