Constant high engine rev after a push start?
Old Feb 27, 2012 | 09:11 AM
Lucero1's Avatar
Lucero1
Default Constant high engine rev after a push start?
While riding this past Saturday, my buddy had his battery go dead about halfway through the trip.
We were able to push start it at a couple of stops heading home, but after the third time the engine would not idle down...no matter what we tried.
I'm no mechanic, but I suspect that the computer wasn't getting enough juice from the battery to adjust the electronic fuel injection...but that is just my own uneducated guess.
Luckily, he had AAA+, which came and got the bike and towed it home.
If it was simply a battery issue, do you think this will be resolved once he puts a new battery in?
Thanks,
Scott
Old Feb 27, 2012 | 09:29 AM
Hocus-Pocus's Avatar
Hocus-Pocus
Sounds like it quit charging. I would check output when you put the new battery on it.
Old Feb 27, 2012 | 11:40 AM
piasspj's Avatar
piasspj
Isn't an 08 Touring bike by chance?
If so there is a slight bug in the TBW. Cause is hitting the kill switch with the throttle partially open.
Fix is to cycle the Ignition switch 4 times leaving it in each position (off/run) for a few seconds.
mang0
Aug 20, 2018 04:04 PM
kareengas
Feb 4, 2016 08:59 PM
MCarbonaro
Jul 2, 2013 07:06 AM
Houlie
Apr 29, 2013 10:22 AM
gregorysfd
Mar 13, 2008 08:33 PM
