Periodic High Idle
Old Sep 16, 2012 | 10:24 PM
myrtle2008's Avatar
myrtle2008
2nd Gear
Default Periodic High Idle
My 08' Nightster (fuel injected) will occasionally (usually once every ride) start idling higher than normal. I can tell when it's going to do it because when I let off of the throttle I can feel it pushing as I'm coasting. Then when I get caught at a traffic light, it will idle high for about thirty seconds and return to normal idle speed. After that, everything is fine. I'm thinking there is a leak in a gasket somewhere between the injector body and the intake manifold, causing too much air to enter. Anybody had a similar problem or heard of something like this?
Old Sep 17, 2012 | 05:51 AM
NightHunter's Avatar
NightHunter
I get that to, not sure what the heck it is, comes and goes, ??? right now hasn't showed up lately? i'll be waiting for a explanation on this too, sorry no help here,
Old Sep 17, 2012 | 10:04 AM
patrickd's Avatar
patrickd
It's happened to me once. Came off the interstate to a red light and the idle was up to 1400rpms. Lasted about 10 seconds. I ride 2012 FXDWG with about 5000 miles on it.
Old Sep 17, 2012 | 12:15 PM
nevil's Avatar
nevil
First thing I would do is clean your IAC.
Old Sep 17, 2012 | 06:41 PM
Nevar's Avatar
Nevar
Plus one on the IAC. I had the same thing after a long ride.
Cleaned the IAC. Seems ok now.
Old Sep 17, 2012 | 06:52 PM
Mr. Lucky's Avatar
Mr. Lucky
If the IAC checks out, verify that your crank posotion sensor isn't loose, and also check for any codes.
Old Sep 17, 2012 | 07:03 PM
checkers's Avatar
checkers
My '11 Heritage does this at times also, it "feels" like the ECM is doing it. I think it's a normal issue.
Old Sep 17, 2012 | 08:37 PM
hdgzr's Avatar
hdgzr
My '11 Heritage is currently in the shop hopefully getting this very thing taken care of. My Indy thinks it's the fuel pressure regulator without even looking at the bike. The dealership thinks it's something else, as the O2 sensors are not responding as they run diagnostics.
I'm suspect of the dyno tune when the SE Race Tuner was installed, as the Indy only made two runs; I've checked with several tuners in the meantime who've stated it should take considerably more time than that.
I guess time will tell...
Old Sep 17, 2012 | 09:47 PM
V2Evo96's Avatar
V2Evo96
Subscribed-- My 09 ultra has starte doing this as well. High idle for about 30 seconds then normal idle.
Have read on another site that the TCA (Throttle Control Actuator) pins can get scuzzy with grime, electrolysis, etc and casue the same event.
Old Sep 18, 2012 | 01:00 AM
myrtle2008's Avatar
myrtle2008
2nd Gear
Well it sounds like I'm not the only one with this issue. A buddy of mine told me to spray some WD-40 or something comperable where the intake meets the jugs. If it starts sputtering or idling funny, then I do have a leak at the seals. Pretty much trial and error from here on out it looks like. Thanks for the input folks! I'll gladly take more input as well.....
scotsport
Sep 21, 2013 03:43 PM
madchemist24
May 28, 2011 06:40 PM
scuba biker
Jun 24, 2010 12:51 PM
Sketz
Feb 19, 2009 07:40 PM
joe v
Aug 26, 2007 08:31 PM
