Burnt material On pipes.
Old Jan 20, 2013 | 07:50 PM
Rumble Bee's Avatar
Rumble Bee
3rd Gear
Unhappy Burnt material On pipes.
I burnt some material on my new 13 classic pipes. The size of a half dollar.
Whats the best way to remove it with out hurting the chrome exhaust cover?
Need help. Thanks
Old Jan 20, 2013 | 08:02 PM
Stangheel's Avatar
Stangheel
https://www.hdforums.com/forum/gener...y-exhaust.html
check out this thread by clicking the link... or just looking at the thread below this one...
coop creek's Avatar
coop creek
Topic covered many times. Easy off oven cleaner, protect all painted surfaces, motor, etc, then apply oven cleaner to chrome, let sit overnite, then sponge it off with H20
Old Jan 20, 2013 | 10:07 PM
one-up's Avatar
one-up
I use Comet scouring powder (the non-abrasive kind) and 3M scrubbing pad (the green ones). Wet the pad, put the Comet on the pad and rub on the nasty spot.
I also use this method to get the glue off the air cleaner cover after pealing off that ugly label that's on the top of it. There's always a glue residue that is really tough to get off. Comet, water and a scrubby pad work well and doesn't scratch.
Old Jan 20, 2013 | 10:37 PM
stonesmith's Avatar
stonesmith
I've had good luck using a heat gun. Heat put it on, heat took it off.
Old Jan 21, 2013 | 11:46 AM
wyndnface's Avatar
wyndnface
Old Jan 21, 2013 | 12:30 PM
Scrmnvtwins's Avatar
Scrmnvtwins
WD-40 on the pipes, let soak overnight and wipe away tomorrow
Old Jan 21, 2013 | 01:37 PM
Rumble Bee's Avatar
Rumble Bee
3rd Gear
Big Thanks for the replies!!!!!!!!!!!!
I am new to the Harley World and have learned two lessons.
1 Do Not wear shorts! Enought said
2 Do Not wear material that melts to the pipes! Daaaa
Old Jan 21, 2013 | 02:19 PM
Def Mute's Avatar
Def Mute
Although lessons learned through experience are often difficult to accept, they will most often be longer lasting than by any other method...
Old Jan 21, 2013 | 02:30 PM
Sharkman73's Avatar
Sharkman73
This.
Or use a better penetrant oil like Aero Kroil...it will work faster.
