Floating rotor noise, normal or excessive?
Old Jun 2, 2013 | 11:10 PM
Olsen185's Avatar
Olsen185
Default Floating rotor noise, normal or excessive?
http://i149.photobucket.com/albums/s...psf6c56238.mp4
I can't figure out how to embed the video so I posted the link
Is this rotor play normal for floating rotors? They make tons of noise when I hit bumps. I can't remember having the same issues on my old bikes
Old Jun 3, 2013 | 01:19 AM
Daddy-O's Avatar
Daddy-O
I have a Brembo floating rotor and any movement is barely perceptible. Nothing like your video. Not sure if they're all the same.
Old Jun 3, 2013 | 01:56 AM
Daddy-O's Avatar
Daddy-O
Looks like some movement (and noise) may be normal for full floating rotors http://www.braketech.com/index.php?o...talk&Itemid=69
Although yours look looser than anything I could find on youtube. Also, the play is usually side to side not around the circumference.
Old Jun 3, 2013 | 03:40 AM
DonN's Avatar
DonN
The Harley floating rotors are really not floating and do not allow any movement. Just the rotor is separated from the center section to dissipate heat but is attached pretty solid. Not sure what brand you have on yours.
Old Jun 3, 2013 | 03:43 AM
DOMAPOI's Avatar
DOMAPOI
Never seen one that loose before. You may want to go to your local service center, show and ask them what they think. If they say it is a bad thing buy a new rotor and rotor screws (never reuse those) and install it yourself.
Old Jun 3, 2013 | 09:44 AM
Olsen185's Avatar
Olsen185
Thanks for the help. The bike has 18,000 miles so I'm not sure if the pins/bobbins are worn, or if it was normal. I'll have to buy some new ones and measure the difference in thickness.
Old Jun 3, 2013 | 09:50 AM
electricstart's Avatar
electricstart
That would drive me crazy too,I guess you hear when you are riding. That does look like a lot of movement.
Old Jun 3, 2013 | 10:16 AM
Olsen185's Avatar
Olsen185
The only time it makes noise is when I hit bumps. If I'm on the brakes when I hit the bump then it doesn't rattle, but if I'm not on the brakes it sounds like the front end is falling off.
Old Jun 3, 2013 | 10:49 AM
jakenok's Avatar
jakenok
sounds like the pins are loose
Old Jun 3, 2013 | 12:24 PM
Simple Man's Avatar
Simple Man
Heat dissipation? Never heard it explained that way before before. I have to disagree with you. The Harley floating rotors I have seen are just that, floating rotors. Just because they are called floating rotors does not mean you can move them. They are floating to allow for expansion due to heat to help keep them from warping.
Play in a brake rotor is not a good thing. Yours is junk. Do yourself a favor and replace it with a good quality rotor and new pads as soon as possible.
BrysZ
Oct 24, 2018 07:18 AM
SeniorChief56
Wheels/Tires
Feb 4, 2014 07:58 PM
pblanton
Jul 29, 2010 05:01 PM
mmgogos
Oct 22, 2007 02:40 PM
Anthony8858
Aug 14, 2006 10:30 PM
