Help! Engine casing finish damaged
Old Aug 30, 2015 | 03:23 PM
jrdn003's Avatar
jrdn003
Default Help! Engine casing finish damaged
Like every sportster had some oil leak from beather bolts on camsaft casing. Dont ask why but didnt clean it up right away.
Wash the bike yesterday and apply wheel degreaser to remove oil and it completly damaged the finish. I need your help guys for options to correct this thannks
Old Aug 30, 2015 | 05:10 PM
Nitro 54's Avatar
Nitro 54
WOW, that was some strong *** degreaser you used! I would pull the damaged covers off and get them powder coated.
Old Aug 30, 2015 | 05:19 PM
jm35ny's Avatar
jm35ny
Try the S100 or other brand of engine brightener and see how it looks. Otherwise you might have to paint/powder coat them
Old Aug 30, 2015 | 08:00 PM
union53's Avatar
union53
I would try some simple green on it. Stuff works wonders sometimes.
Old Aug 31, 2015 | 08:55 AM
01fxdxt's Avatar
01fxdxt
Can't turn the clock back ,but soak it with WD 40 ,let sit ,wipe with terrycloth.You can leave that on forever and it won't hurt.I buy wd40 by the gallon and soak my motorcycle metal parts and leave for winter storage,they still look new.ALWAYS use the least strong chemical first.Sorry for your mishap.Try this but dont get it near your brakes,oh and tires of course,this should be pretty obvious.Good luck
Old Aug 31, 2015 | 09:38 AM
r1cochet's Avatar
r1cochet
Can also try some silicone spray (test in a small area first). Worked well for me in the crinkle-black areas of my engine. Caveat: a lot of people avoid silicone spray as it makes the area hard to paint in the future.
Old Aug 31, 2015 | 10:59 AM
jrdn003's Avatar
jrdn003
What type of silicone spray??
Old Aug 31, 2015 | 12:20 PM
r1cochet's Avatar
r1cochet
Hi, I have a can of general silicone lube like this: http://www.canadiantire.ca/en/pdp/mo...l#.VeSL09fD9aQ
I use it mostly for the rubber weather stripping seals on my truck - I park outside and the silicone helps stop ice freezing on top of the door/seal during the winter.
I read somewhere that the engine-black products (s100 engine brightener, pigspit) contain silicone as the active ingredient. I tried some of my general purpose silicone lube spray and it worked very well to restore the crinkle paint back to a dark black.
Old Sep 1, 2015 | 03:28 PM
dfwhockey17's Avatar
dfwhockey17
DOT 5 brake fluid is silicone based and will darken up the cases similar to the spray or S100 engine brightener...
BobbyVera
May 13, 2013 07:20 PM
HotIceHD
Jul 13, 2012 12:03 PM
gator9999
Feb 18, 2009 09:43 PM
Bluesrider
Jun 27, 2007 12:06 AM
dxrich
Aug 30, 2006 12:43 AM
