Stubborn fork dust covers
Old Aug 30, 2015 | 07:43 PM
Wadgegirl's Avatar
Wadgegirl
Stage II
Default Stubborn fork dust covers
I have an 05 sporty that started leaking oil from the left fork. I'm trying to clean out the seal but I can't get the damn dust cover off. I've tried WD to try can and lube it. Putty knife, chisel, screw driver.....doesn't even budge. Any advice?
Old Aug 30, 2015 | 08:02 PM
union53's Avatar
union53
Give it a pop with a soft faced hammer. However just cleaning out the seal most likely wont fix your leak. Probably time to get the forks serviced.
Old Aug 31, 2015 | 09:04 AM
01fxdxt's Avatar
01fxdxt
Soak joint with WD40,look for a small notch at that joint.Use a hardwood dowel ,tap gently,once it starts go around evenly a little at a time,no need for berserking here....
joe40x
Sep 4, 2018 10:54 AM
Filmy
Jun 10, 2009 02:01 AM
doulos
May 26, 2008 02:58 PM
DWhite
Apr 22, 2008 03:52 PM
imboden
Jul 19, 2007 03:33 PM
