Sounds like I'm grinding coffee
Old Sep 5, 2015 | 07:27 PM
Moses2's Avatar
Moses2
Default Sounds like I'm grinding coffee
my starter (2010 ultra limited) has been sounding like its grinding up some coffee beans lately, when I go to start. Replaced the battery after I did a load test. Thought That was it, but it's back. It's intermittent but getting more frequent. Starter engages ( no bang) and then disengages and starts grinding the beans. I let off the start button and then try again. I have read sprag clutch and compensator I just want to get what I need for parts, good instructions and replace 'em. Share your thoughts. Neil, I know you're out there. Thanks everyone.
Old Sep 8, 2015 | 12:04 AM
dfwhockey17's Avatar
dfwhockey17
Compensators fail often and will make the noises you are hearing. To diagnose it properly as to not buy extra parts you will need to pull open the primary and inspect everything. Check the torque on the compensator bolt as they like to back out and cause havoc in your primary. Also check the wear on your pinion and ring gear.
Old Sep 9, 2015 | 07:18 AM
Moses2's Avatar
Moses2
Thank you. Due for an oil change, so I'll have at it. When it happens, it can take 3-4 attempts to start. After that it can have repeatedly perfect starts.
Old Sep 9, 2015 | 09:39 AM
Next In Line's Avatar
Next In Line
Is there missing teeth on your starter ring gear?
Old Sep 10, 2015 | 01:38 PM
Moses2's Avatar
Moses2
Will I be able to inspect the ring gear with the primary cover off?
Old Sep 10, 2015 | 03:41 PM
dfwhockey17
^Yes you will.
wycked
EVO
Nov 21, 2021 06:40 PM
Jasper86
EVO
25
Aug 6, 2014 05:14 PM
Romprunner714
Jun 16, 2014 11:01 PM
95 Ultra
EVO
Mar 31, 2012 06:12 PM
Spades
Shovelhead
May 10, 2010 10:26 AM
