Delkron cases
Old May 5, 2007 | 05:13 AM
Loaf's Avatar
Loaf
6th Gear
Default Delkron cases
G'day gang, Just trying to figure out a problem with a set of Delkron cases. Have bought arebuilt Evomotor to throw into my 89 Electra-Glide but there is a threaded hole in the cases beside the oil pump. Anyone know what this is for? The motor is a late Evo (I think the guy said it was a 97 or 98). Just want to get it right so the old girl can be put back on the road. Hope somone can help me out here I don't want to feel like a goose when I talk to the bike shop.
Loaf
frustrated Aussie
Old May 5, 2007 | 05:47 PM
pococj's Avatar
pococj
Default RE: Delkron cases
If you get nothing, try e-mailing Delkron.
Old May 6, 2007 | 10:03 AM
Loaf's Avatar
Loaf
6th Gear
Thanks Skip, Tried that a little while ago and got no reply from the ignorant baaastards. Will try it again though thanks for the jog. Did it through their old website not the new fandangled one they've got now. May be it got lost in the changeover (here's hoping).
Loaf
Old May 22, 2007 | 11:22 AM
shtfaced's Avatar
shtfaced
If it's a Pipe Plug Threadded Hole just to the inside of the Oil Pump Mounting Surface,( and maybe down a little),it'sa crank case vent hole. S+S ships many of there Evo Style motor's with a barbed fitting in that hole for a 3/8" id vent hose in that spot. If your not going to use it, ( and you might want to depending on how your older Glide was setup for crank case venting), just plug it, or better yet, put a barbed fitting on it with a 90 degree bend, facing up, and then plug the barbed fitting with one of them little boots they make, or a piece of hose with a bolt in it, and a couple of clamps. That way if you decide to use it later, you just need to run a vent hose off the allready in place barbed fitting. I have a 96" S+S Im using on a chop project I'm building, and I just have the barbed fitting with the little boot over it to block it off. I'm not using the extra Crank Case Vent because my oil bag is well above my oil pump, and for some reason it's not usually required for that type oil bag setup.
Now on your Electra Glide, you may well need the extra vent. Not sure why that is, but that's what I know from reading the S+S Tech sheets that came with my motor.
Hope this helps.
Shtfaced (Tim).
Old May 22, 2007 | 11:37 AM
MikeyB's Avatar
MikeyB
Yep. That's the vent on the early style Evos. I have a remote breather attached there.
MikeyB
Old May 22, 2007 | 07:23 PM
Loaf's Avatar
Loaf
6th Gear
Thanks heaps Tim and MikeyB will get a beather for it. The motor is a breathe through the heads motor unlike my old motor which had the breather out beside the oil pump and into the air filter. Will run an additional breather and give it a go.
Loaf
Old Feb 20, 2020 | 09:52 AM
Rusty E Good's Avatar
Rusty E Good
It’s the vent for bottom breather engines. In other words if your heads don’t have breather ports it’s used as a breather. Simply put fitting on and run a hose. If you have breather heads than plug it. Your 89 original engine is a bottom breather setup
Old Feb 20, 2020 | 03:57 PM
Max Headflow's Avatar
Max Headflow
After almost 13 years, I'd say you are a little slow to the party.
Old Feb 21, 2020 | 05:11 AM
Rusty E Good
my pops always said it’s better late than never. Lol
jag40oz
Engine Mechanical Topics
Mar 31, 2016 06:32 AM
SleepyBagger
33
Jul 27, 2015 03:59 PM
heavyd1951
Shovelhead
Jan 12, 2012 04:55 PM
Mr. Wannabe
Shovelhead
11
Jul 19, 2011 07:04 PM
doreenhart77@yahoo.com
Oil Archive (no new posts)
Jun 12, 2011 03:32 PM
