How to take handlebar left grip?
Old Apr 26, 2016 | 12:19 PM
caleborlando`'s Avatar
caleborlando`
Default How to take handlebar left grip?
Does any one knows a tip or trick to take out the stock left grip? I know the stock one have small quuantity of glue.
Any help?
Old Apr 26, 2016 | 01:12 PM
enodrano's Avatar
enodrano
There is no glue on a modern stock Harley OEM grip. Some aftermarket grips require the left grip to be glued, but the Harley-Davidson branded grips have a ridge that is secured when the housing is clamped together. You have to take the housing apart just like you would for the right grip.
Old Apr 26, 2016 | 01:14 PM
caleborlando`
Well. Not in the sportster 2015. Is glue.
Old Apr 26, 2016 | 02:10 PM
Longridertx's Avatar
Longridertx
Slice the grip length ways with a razor knife, then twist and pull off. Or just get a good grip on it and twist if you want to save the old grip. Sand off the old glue with fine sandpaper or emery cloth and install your new grip.
Old Apr 26, 2016 | 09:08 PM
Dalt10's Avatar
Dalt10
My '15 had glue. Used a razor knife and cut it off.
Old Apr 26, 2016 | 10:03 PM
Longridertx
So did mine. I didn't want to cut it so I just got a good grip and twisted it and it broke loose. Came off easy then.
Old Apr 27, 2016 | 04:18 AM
Scott Grout's Avatar
Scott Grout
I used a small rubber strap wrench to break the glue bond. I started at one end and worked my way to the other end. After the bond was broke it came off easily.
Old Apr 27, 2016 | 06:50 AM
caleborlando`
Thanks for your comments! Yes. I don't want to cut it. I like the stock one. Somebody told me long time ago, to use a spray product, i don't remember, but it was for other purpose, but activate the glue again and it easy to take it out. I was hopping that somebody knew.
Thanks again. Im going ro try to twisted it.
Old Apr 27, 2016 | 07:04 AM
cocky's Avatar
cocky
Crank up the air compressor and blow shop air between the grip and bar. Squeeze the open end with your hand and the grip will expand like a balloon and can be slid off intact.
Old Apr 28, 2016 | 09:49 PM
caleborlando`
That's good idea. Im going to try that
Royal Tango
2014-2024 Touring Models
11
Nov 1, 2015 05:14 AM
pomeara
Feb 1, 2014 09:03 AM
straps
Mar 15, 2011 07:03 PM
wayne72472
Jan 19, 2009 12:00 AM
twoseas
Nov 29, 2006 06:34 PM
