Camchest oil quantity
Old Jun 13, 2016 | 09:46 AM
martin10's Avatar
martin10
On Softails oil will drain from the tank back into the cam chest. It is normal. Some do it worse than others. You will have a lot more oil drain out on a Softail
Old Jun 21, 2016 | 05:49 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by carbonslave
I just got done putting cams in my bike whenever I open the can chest to make sure the oil was circulating it seems like an unusual amount came out right at three quarters of a quart how much should be in there?
Your amount sounds a little high.. If the bike was running while leaning on the sidestand, you might get 2 cups but no as much as you say.. Bike level, oil level at the pump should be a whisker above the pickup..
There may be problems with oil pump assembly, problems with the cam plate or simply sumping from the oil tank in a softails or oil running forward out the filter on a bagger or dyna if the bike has been sitting. Model and Year plus what you just did would be of help..
carbonslave
Jun 10, 2016 09:26 AM
zach smith
Engine Mechanical Topics
Aug 5, 2015 11:49 AM
BIGREW
Jul 25, 2011 12:18 PM
Tanker2
May 9, 2011 11:01 AM
ziggy
Mar 28, 2010 11:41 AM
