Bolt removal
Old Apr 20, 2017 | 08:01 AM
JVR's Avatar
JVR
Smile Bolt removal
I have a question. Iam getting ready to remove my stator on my 2006 Dyna. I read the material Harley uses on it boltsto prevent loosing is very corrosive, destroys threads, and must be totally removed from thethreads. Is this true.
Old Apr 20, 2017 | 11:56 AM
nevil's Avatar
nevil
What does the service manual tell you to do? I would look it up for you but my manual is in the garage and I can't get to it for a while.
Not sure what you were reading but I can't imagine that HD uses a threadlocker that destroys threads.
You can always just get new bolts.
However, I'm sure those who have done it will be able to tell you.
Old Apr 20, 2017 | 01:36 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
I changed a stator before and never removed the factory loctite. The bolts are specifically "stator bolts" - made for that exact purpose.
Old Apr 21, 2017 | 05:52 AM
Vernal's Avatar
Vernal
Sounds like more than one person needs to read the Service Manual........
Old Apr 21, 2017 | 10:58 AM
Gozzie's Avatar
Gozzie
I have a tap and dye set that I use to clean and chase threads. You can find a cheap set from most cheap wholesalers.
Old Apr 21, 2017 | 09:46 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
This^^
Always chase threads to clean out debris and old thread locker and apply fresh thread locker to clean threads with primer where called for
flipbel
Feb 23, 2011 08:43 AM
weekender2098
Oct 3, 2010 06:03 PM
roach
Shovelhead
Jun 30, 2008 12:22 AM
poolman
May 28, 2008 02:47 AM
isitmondayet
Feb 11, 2008 07:44 PM
