Shovel hard acceleration plus backfires
Old Jun 12, 2017 | 05:26 PM
kapow's Avatar
kapow
4th Gear
Default Shovel hard acceleration plus backfires
Im trying to get a 75 shovel that I just bought on the road and there's a few problems I can't fix with the limited mech skills I have.
It starts fine. A bit hard but when it's warm it's acting up. First it goes, hesitates then it wants to die. I try to accelerate but I get the stuttering and the backfires. It won't even go in first without heavy clutch action.
The plugs are black so I'm guessing to rich and I've tested the charging system.
4 pin stator.
Wh to wh = 65V a/c
Bl to Rd = 105V a/c
Points are good.
Can't say about the condenser
Didn't test the coil.
Can someone help me out with troubleshooting.?
Old Jun 12, 2017 | 09:18 PM
brntkndll's Avatar
brntkndll
What are you running for a carb. If your plugs are Sooty black you're definitely running rich. Wet black would be oil contamination. The first thing I would do is properly adjust the carb,check the points,Clean and lubricate the advance unit, REPLACE the condenser. The condensers manufactured today are garbage. The best thing I ever did to my shovel was converting her to electronic ignition. That solved a whole shitload of issues....Good luck with it.
Old Jun 12, 2017 | 10:38 PM
kapow's Avatar
kapow
4th Gear
Thanks. The condenser is number one on my list. I run a keihin carb with a 175 main jet. Does it matter if the oil seal bearing is leaking a bit of oil in the ignition timing. Where the points are?
Old Jun 13, 2017 | 07:00 AM
brntkndll's Avatar
brntkndll
Hell yeah it matters if it's getting the points covered in oil. Clean them up good with a blast of brake cleaner.
Old Jun 17, 2017 | 05:46 PM
Hey Man's Avatar
Hey Man
Points are good.
First step. You have a manual, right?
Change the condenser and if it's skipping check for points bounce and suspect the coil. If the coil or condenser are causing the miss remember that even though the engine doesn't fire gas is still being dumped into the cylinder. When that extra gas fires it can cause symptoms of running rich. And while you have that stuff out of the cone, replace the oil seal. You shouldn't have oil flying around in there.
Remember - gas, air and spark in the proper ratio makes it run well. Work on one thing at a time. The easiest are points, plugs and condenser so start there. And while you have that stuff out of the cone, replace the oil seal. You shouldn't have oil flying around in there.
Old Jun 26, 2017 | 09:15 PM
kapow's Avatar
kapow
4th Gear
I appreciate your answer. And I always have the manual.
I've gotten back to troubleshooting again after I've changed a bad coil. It was all cracked up and fixed the bad sparking and backfires. But now when I ride it at idle or even at highway speed it dies while I'm driving. I stop on the side of the road and it starts again. I'M thinking bad stator/rectifier? or ground issue. The stator is reading 105v AC. I think I'm supposed to have 120v AC?
Old Jun 26, 2017 | 09:24 PM
TwiZted Biker's Avatar
TwiZted Biker
Sounds like it's starving for gas. Drain the tank and pull the petcock, even bet the filter screens gummed up. Also check the right side gas cap and make sure the vent isn't plugged up.
Old Jun 27, 2017 | 12:10 PM
roussfam's Avatar
roussfam
TinySAV
Jul 1, 2022 11:57 AM
jimmyjennings60@gmail.com
Jan 14, 2019 10:38 AM
mykechambers
Ironhead
Aug 10, 2014 09:53 AM
shovelhead716
Shovelhead
May 23, 2011 06:39 PM
dyna_man05
Exhaust System Topics
May 3, 2008 11:46 AM
