Frame swap
Old Dec 6, 2017 | 04:21 PM
Kickzip's Avatar
Kickzip
Stage I
Default Frame swap
I have a wrecked 2005 FLHT that I need to get a new frame for. What year frames will work?
Old Dec 7, 2017 | 06:43 AM
YourBikeSux's Avatar
YourBikeSux
Stage II
Anything Twin Cam 1999-up
Old Dec 7, 2017 | 09:23 AM
grbrown's Avatar
grbrown
Wink
You can check matching part numbers on-line here. The frame remained unchanged until 2008 AFAIK, although there may be subtle minor changes along the way. Your bike had frame #47900-02A.
Old Dec 7, 2017 | 10:25 AM
Max Headflow's Avatar
Max Headflow
I would stick with 02 to 06. If you look at the parts diagrams they are the same MPN. 07 might work as with the earlier frames but you will likely find some bracket that holds some part different and you have to make mods.. The 08 would not be a good choice as they moved the top motor mount from between the cylinders to the front of the frame so that they could install a 6 gallon fuel tank..
Old Dec 16, 2017 | 07:48 PM
NORTY FLATZ's Avatar
NORTY FLATZ
OP~ welcome to the site.
Soakinwet
Jul 20, 2024 07:52 PM
Jake707SBFMC
Aug 12, 2010 10:06 PM
jsbridgew
Jan 12, 2009 02:58 PM
krismac23
Sep 2, 2008 05:56 PM
xcaret
Shovelhead
Apr 6, 2007 07:26 PM
