laid down my bike
Old Sep 8, 2018 | 08:03 AM
sebe4848's Avatar
sebe4848
Default laid down my bike
Hey guys I'm pretty new to riding here. I have an 02 nighttrain with a carbonated 110, and 6 speed baker. I was turning around off a main street, hit some gravel at 10 mph and the bike slid put from underneath me. Broke a peg, my transmission belt (open drive), my shifter, kickstand was a little messed up but it works just fine now. My shifter.for the transmission is all sorts of loose, all ot does is just move freely and wont engage or disengage the transmission, I tried starting the bike back up after I laid it down but all it did was just click, I had oil coming out of the air intake at the time but it has since stopped. I am looking to repair the bike myself so any help would be appreciated. I do not know the technical names for all the parts yet so i can take videos and pictures as needed. Thank you.
Old Sep 8, 2018 | 08:08 AM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard.
Sounds like you're in over your head mechanically, but the first thing you should get is a Factory Service Manual.
Old Sep 8, 2018 | 08:22 AM
sebe4848's Avatar
sebe4848
I plan on it. I've worked on cars my entire life, done anything from an oil change to a transmission swap on cars. I know they're different but I was hoping to be able to do it all on my own.
Old Sep 8, 2018 | 08:23 AM
Mikerunsjax's Avatar
Mikerunsjax
That sucks, but be grateful that you weren't hurt. The bike can be repaired. Good luck getting it back on the road.
Old Sep 8, 2018 | 08:24 AM
sebe4848's Avatar
sebe4848
Thank you oh I forgot to mention, the shift lever is loose but the linkage when I pull it by hand shifts just fine.
Old Sep 8, 2018 | 08:36 AM
sebe4848's Avatar
sebe4848
I just checked it and I've got a leak somewhere. I have a big puddle of oil underneath the bike now
Old Sep 8, 2018 | 09:13 AM
touchdown's Avatar
touchdown
Hope you get it fixed sounds like faster then 10 mph
Old Sep 8, 2018 | 12:32 PM
Cozz's Avatar
Cozz
Shop manual is a must for what you’re going to do. Sounds like you are up for it. Good luck. Lots of help here too !
Old Sep 12, 2018 | 05:20 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Inspect your shifter linkage. The stock linkage ends are known to shear if they have to transfer enough energy. If this is the culprit, Landmark makes a much stronger unit with real heim joints. Like this-
Old Sep 13, 2018 | 06:48 AM
roussfam's Avatar
roussfam
Carbonated? Sounds like you gave it too much gas,
Redwood361
Sep 26, 2018 10:53 AM
apblingAEW
Jun 8, 2017 08:59 AM
Stape
Dec 24, 2011 07:24 PM
rdowdy95
Welcome Area Only
19
Jun 22, 2011 06:44 PM
hucks 08
Shovelhead
Jun 22, 2011 06:57 AM
