Stripped screw!
Old Mar 13, 2019 | 07:54 PM
Hoginedgewood's Avatar
Hoginedgewood
Those bolts will have lock tite on them.
Dont use cheap tools from Harbor Freight for this!
another option is weld a bolt to the head of the stripped bolt, added benefit is the heat loosens the loctite.
Old Mar 13, 2019 | 08:28 PM
Bama Lee's Avatar
Bama Lee
You can lead a horse to water .........
SNAP...........oh F*CK !!
Old Mar 13, 2019 | 08:47 PM
Jackie Paper's Avatar
Jackie Paper
Pegs have red loctite on them. Even with a impact quality torx and an impact, with out heat, the head of the bolt is pretty trashed. I would carefully drill out just head leaving the remaining stud left for vice grips. Then once peg is off, mapp gas heat with a sheet metal shield to protect frame and it will come right out. Heat, then cold rag, then vice grips.
Pentrant is worthless on locktite till you heat it red and then cool it off. Most of the time, after heat and cooling and then PB Blaster, it will screw out by hand.
Old Mar 13, 2019 | 09:42 PM
TwiZted Biker's Avatar
TwiZted Biker
If you don't speak millimeter what he will try to do is use a 1/8" easy out on a 3/8" bolt trying to use a hot air gun to heat up red loctite, what could possibly go wrong here ?
TiRider
Jan 25, 2018 08:51 AM
Cbb129
Apr 27, 2016 04:29 AM
PhantomMaxx
May 19, 2015 12:38 PM
Aaronbagby
May 9, 2013 09:24 PM
Big Sled
Apr 25, 2008 07:19 PM
