Wheel Install with Foot Pedal Bike Lift
Old Apr 5, 2020 | 12:13 PM
Sparkules's Avatar
Sparkules
Default Wheel Install with Foot Pedal Bike Lift
My old bike lift used a standard 4 ton bottle jack with the round handle, easy to control for wheel reinstall. The hand control allowed a slow lowering for easy alignment of axle holes easy axle install.
The old lift wasn't up to the weight of a newer Road King so I now have a modern jack with the foot pedal release, it's on off release no way to make a slow lowering.
Any tips ? Only thing I can think of is let it drop a bit lower than where the holes align then slowly jack it back up. Not thrilled with a quick drop while keeping the wheel assembly clear of the swing arm or forks.
Old Apr 5, 2020 | 12:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Sorry I can`t offer any help for your current issue, but a mechanical scissor jack is much more suitable for wheel work.
Old Apr 5, 2020 | 09:13 PM
MyFavRk's Avatar
MyFavRk
Agreed , scissor jack would be a better option .
Old Apr 5, 2020 | 09:27 PM
im's Avatar
im
If this a motorcycle jack that is being discussed then maybe a bolt on foot release lever as shown on you tube might help.
1:25 - 2:25 should show what individual did.
Old Apr 5, 2020 | 09:40 PM
BrandonSmith's Avatar
BrandonSmith
You just have to be very very light with your foot.
Old Apr 6, 2020 | 12:53 AM
Sparkules's Avatar
Sparkules
That's exactly what I needed to know, thanks! Bolt thru the pedal, perfect solution for my problem
Old Apr 6, 2020 | 06:46 AM
Architect's Avatar
Architect
I leave the bike and MC lift all they way up. Then I roll over a standard rolling jack ($39.95 at Napa) and put the wheel on that, then jack the wheel UP to the bike. This way the bike stays secure on the lift. Just a thought, good luck.
Old Apr 6, 2020 | 08:49 AM
Sparkules's Avatar
Sparkules
OK another good idea I do have a floor jack
Chunker
Apr 27, 2013 07:49 PM
Chunker
Apr 2, 2013 12:15 PM
coachstorms
Oct 14, 2011 08:56 PM
inswva
May 9, 2011 08:54 PM
QuickSilver74
Sep 2, 2009 08:28 AM
