2013 Touring, slipping in 5th
Old Jan 16, 2022 | 06:35 PM
Marty33's Avatar
Marty33
Default 2013 Touring, slipping in 5th
2013 Road Glide Custom, stock transmission. In 5th gear , under moderate acceleration, rpms increase but very little power is generated. Revs go up but no power in 5th gear. Tranny has 28000 on it.
Is 5th gear or transmission going out? Transmission main bearing drive? Any advice?
Old Jan 16, 2022 | 07:26 PM
SteveMKentucky's Avatar
SteveMKentucky
Sounds like a slipping clutch. Recommend checking all clutch adjustments.
Old Jan 16, 2022 | 08:49 PM
kevin_n's Avatar
kevin_n
Had this problem with my wife’s 13 sg. Did a proper adjustment on the clutch and now noe problem.
Old Jan 17, 2022 | 06:52 PM
Goldstar225's Avatar
Goldstar225
Yes, check your clutch adjustment, starting with the clutch itself, not just the cable.
Old Jan 26, 2022 | 05:42 PM
SteveMKentucky
So tell us...did you check your clutch adjustments? Have you found the problem?
Old Jan 26, 2022 | 06:56 PM
Marty33's Avatar
Marty33
It was a simple clutch adjustment. Thanks guys.
Old Jan 26, 2022 | 06:59 PM
SteveMKentucky
Good to hear.
Old Jan 31, 2022 | 04:49 AM
ratsnest's Avatar
ratsnest
mine did that when I upgraded my Cam.. I switched out the Spring in the clutch basket to the SE Heavy Duty one... and that fixed it
Marty33
Jan 16, 2022 07:08 PM
2013superglideseattle
Milwaukee Eight (M8)
20
Aug 13, 2017 08:33 AM
hardheaded
Aug 2, 2016 09:16 AM
rjayt_2007
Jun 19, 2013 03:03 PM
BobbyHD
Sep 3, 2008 03:42 AM
