Fork reflector removal
Old Jun 11, 2022 | 11:49 AM
cdremy's Avatar
cdremy
Default Fork reflector removal
Would like to remove the reflectors on my 2017. Does the fork have a protective coating that I need to be careful not to remove while lifting the reflector off
Old Jun 11, 2022 | 11:53 AM
brakeless's Avatar
brakeless
Should be held on with a 3M type adhesive tape. A little heat from a hair dryer and it should come right off. Don't use anything metal to pry with. Plastic only.
Old Jun 11, 2022 | 12:13 PM
MCRD'71's Avatar
MCRD'71
Default reflector
hair dryer and dental floss, then wipe with wd-40 for the glue.
Old Jun 11, 2022 | 03:17 PM
470004's Avatar
470004
I use a heat gun (keep moving the heat gun back and forth) and then a piece of 40lbs monofilament fishing line. I cleaned the remaining adhesive with kerosene.
Old Jun 11, 2022 | 07:43 PM
cdremy's Avatar
cdremy
My question had to do with a protective coating on the fork which I was concerned might be taken off during the removal process
Old Jun 11, 2022 | 08:50 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
As long as you use a 'monofilament' line you'll be fine. Don't use a 'braided' fishing line.
Old Jun 13, 2022 | 02:48 PM
maxxym's Avatar
maxxym
It will come right off.. just use heat gun. Mine actually came off clear and I didn't have to work much on the tape thing.
Old Jun 14, 2022 | 10:24 AM
cdremy's Avatar
cdremy
Thanks for the suggestions. Went with the heat gun. fishing line and glue gone. worked great.
run1fsr
Feb 13, 2019 05:56 PM
CRocks
Aug 25, 2012 12:09 AM
odons
Dec 23, 2011 05:07 PM
neverdown
May 14, 2010 02:46 PM
vheflin
Mar 25, 2006 03:52 AM
