Dyna 2010 starts and stops directly
Old Jan 15, 2024 | 09:14 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Originally Posted by Jackie Paper
Wow. What a fix thanks to Coolbreeze. So, jiffy stand safety switch needs to be added to the call out on bikes that have it for engine stall after start.
Anyone know the year it and the netural switch started?
When it's right, does the stand stitch kill motor if not in neutral?
Not on the US bikes yet. The give away is the OPs location - Spain.
Old Jan 15, 2024 | 09:33 AM
CoolBreeze3646
Originally Posted by Francke
Thanks all, I follow all yours advice. The jiffyswitch is the bad guy.
Now the bike works if I fold in the jiffy stand. still dying when i drop out the jiffy which seems a bit wonky with the N gear in but at least now i have something to go on.
And if I can't find the fault, I can at least take it to a workshop
Thanks again!
@Francke You bike has 3 neutral safety switches, Jiffy Stand, Clutch Lever, and Transmission.
The jiffy stand switch is working as intended if it shuts the bike off when it is dropped, the transmission neutral switch is working if the bike will start in neutral with the kickstand up.
The next place to look is the switch in the clutch lever switch pack housing.
Try having the clutch pulled in and dropping the kickstand while in neutral gear, that may isolate the issue.
If it does not, I don't have anything further to provide as I am not that familiar with how the jiffy stand neutral system works on non-US motorcycles.
Check the pins on the jiffy stand connector if you disconnected it changing the battery. Also any work done on the handlebars?
Ref:14
71620-08
SWITCH CLUTCH, W/ 10181 & 72266-94
Price: $72.41
Ref:10
33926-06B
NEUTRAL SWITCH W/ O-RING
Price: $18.99
StewedScrewed'N'Tattooed
Engine Mechanical Topics
14
Jan 4, 2022 09:47 AM
Thozmosis77
Sep 19, 2020 02:57 PM
Jzucca
Electrical/Lighting/Alarm
Mar 20, 2019 12:33 PM
Streetrunner
May 20, 2014 08:55 PM
mang0
Jul 15, 2012 05:08 PM
