General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
It seems we are still none the wiser as to what scanner you refer.
Now if you mean an OBD scanner then if it is made for the HD bike it will pick up the power that is provided at the 6 pin connector.
To pull the power and ground pins from the plug and use an isolated power supply will probably not work as the negative wires will not be connected and referenced at the same ground plain. The scanner will thus probably not work.
Originally Posted by Rounders
Anyone use a 12 volt source to power scanners rather than powering off bike?
Probably waste of money since you got to pull side cover off anyways. Bs.
yes I know how to use it. Interesting idea about ground reference. i work with DC systems. Main systems are grounded, and you can read + and minus to ground, but other systems are not and you can only read across, but not to ground.
It would depend how it is using the power. Is it just power its brains up and closing dry contacts or wetting something through the scanner. I suspect it is operating dry contacts, that are being supplied by the bike itself. But I am curious and good question.
