Sunpie LED headlight
Old May 3, 2024 | 05:25 AM
prockey's Avatar
prockey
Default Sunpie LED headlight
I bought a LED headlight from Sunpie for my ‘09 FLHP and it was the one the salesperson said I needed but the mounting ring won’t fit inside the bucket so that the flange sits properly.
I’ve tried everything I can think of to make it work with no luck. Before I return it I wanted to check if there was something I’m missing.
in the pic it shows how it’s too wide to go inside the light bucket.
Old May 3, 2024 | 06:37 AM
Rounders's Avatar
Rounders
I did mine on a 2007. The video sure makes it look easy. But lot more screwing around figure out which way it goes, should I use this part from stock. No help other than it does take more thinking that I thought. Simply because I never did it before, and I sure it would be just as hard since it has been a few years.
Old May 3, 2024 | 07:59 PM
prockey's Avatar
prockey
The only way I can see to make it fit is to grind off about 5/16 inch on the flange where the yellow arrow is pointing in the pic above. That would come very close to the spring.
I'm still waiting to hear from Sunpie to see if they have a different version of the headlight for the FLHP.
Old May 3, 2024 | 09:14 PM
96hugger's Avatar
96hugger
Would this not simply be solved by opening the nacelle?
Old May 4, 2024 | 05:31 AM
prockey's Avatar
prockey
That is an interesting option that I was looking at yesterday. My concern is that it would be very involved to do that. I didn't explore it a lot but it looks like I would have to remove quite a bit in order to do that and then if I need to access the wiring in there in the future, I'd have to repeat it.
The nacelle wraps around the sides of the forks and then is under the tach.
I'll take another look, but thanks for that suggestion.
Old May 4, 2024 | 06:55 AM
Rounders's Avatar
Rounders
I would contact them, as you did.
Old May 4, 2024 | 07:14 AM
prockey's Avatar
prockey
I have been back and forth with the company and sent them pics, but they don't seem to understand what the problem is. They keep insisting it should fit but I'm getting the impression that there is something different in the nacelle of a FLHP and other Road Kings.
Old May 4, 2024 | 07:18 AM
Rounders's Avatar
Rounders
Originally Posted by prockey
I h different in the nacelle of a FLHP and other Road Kings.
That may be, or they don't care or lost in translation. But being different is very good guess.
Old May 4, 2024 | 09:37 AM
Weeboy1's Avatar
Weeboy1
Not sure if my situation is similar but I didn’t like the gap left by the included adapter so I modified my oem bucket to accept the Sunpie headlight. Involves cutting the back of metal bucket but it worked for me.
Old May 4, 2024 | 10:53 AM
YZR's Avatar
YZR
Deleted
