Cubic Inches, Stroke, Saddle Height?
Old May 28, 2024 | 10:54 AM
Evo-Wes's Avatar
Evo-Wes
Default Cubic Inches, Stroke, Saddle Height?
In order to educate myself, I would like for you all to inform me about increased cubic inches (CI) and engine height relationship.
Does Harley-Davidson maintain the square of the engines as the CI increase? Or do the larger bore engines tend toward oversquare? Or is the stroke increased to maintain the HD stroke to CI. (I am assuming that HD factory engines are undersquare?)
Comparing an 80 CI to a 114 CI, is the overall height of the engine different?
Does this increase the saddle height from the ground?
Old May 28, 2024 | 11:19 AM
Buelligan666's Avatar
Buelligan666
No. Lol.
Old May 28, 2024 | 12:11 PM
Evo-Wes's Avatar
Evo-Wes
I appreciate your response, but could you elaborate?
Is the stroke also increased with the cubic inch increase, so as to maintain the undersquare?
Or does the increase CI cause the undersquare to drift toward square?
Old May 28, 2024 | 12:18 PM
Buelligan666
The bore is the diameter of the cylinder
The stroke is made with the crank shaft and/or connecting rods.
The cylinder height doesn't change.
Same frame = same seat height. They don't make different frames for different engine sizes.
96" is a bored 88"
103" is a stroked 96" or stroked and bored 88"
I don't know all the geometry and math involved. I'm an electrician, not a mechanical engineer.
Old May 28, 2024 | 12:20 PM
Goose_NC's Avatar
Goose_NC
There are many Harley engines from 1985. 80, 88, 96, 103, 107, 110, 114, 117,123. You will need to look at the specifications for all those configurations as they are different pistons, strokes, cams and EFI programming.
That is just for stock Harley engines. Not the many aftermarket configurations available.
The 114 is a "stroker" motor 4.0 x 4.5 inches and I like my 2019 114 in my FLHTP. Google the different Harley engines for the bore x stroke specifications.
Old May 28, 2024 | 12:46 PM
eighteight's Avatar
eighteight
Originally Posted by Buelligan666
The cylinder height doesn`t change
Right, notice the exhaust port location never changed from EVO thru all the T/C variants.
Old May 28, 2024 | 01:21 PM
Evo-Wes's Avatar
Evo-Wes
Good information. Thanks.
I am understanding that stroke changes with the CI increase.
And I am also assuming that Harley-Davidson maintains the same engine height by relocating the wrist pin location on the piston (in relation to the head of the piston) to keep the piston from hitting the head.
And that they also shorten the piston length so that they can keep the same cylinder length.
And that the throw of the crankshaft increases to increase the stroke.
My curiosity is greatly aided by your replies. I will now start researching the various engines as you have suggested.
(By the way, mechanical engineers deal with very many other varied fields beside ICE engines.)
Old May 28, 2024 | 04:13 PM
Buelligan666
I'm aware, they can screw up things in every industry. I deal with them first hand.
Old May 28, 2024 | 06:08 PM
Evo-Wes's Avatar
Evo-Wes
I agree, as with any occupation in any field.
Bill wallace
Engine Mechanical Topics
60
May 22, 2019 09:55 AM
RexD
Sep 9, 2015 06:47 PM
KRUNCH
Jun 9, 2007 07:18 PM
scttgr8
Dec 27, 2006 02:57 PM
witch1
Jan 21, 2006 10:52 PM
