Help! Stuck fork lock 2008 Sportster
Old Nov 1, 2024 | 05:27 PM
elPrez's Avatar
elPrez
Originally Posted by roussfam
Please let us know how he made out....
I will, no luck so far. He stopped working on it because he’s preparing for an interview for a new job plus flying home for a wedding. He’ll try again when he gets home but I have a feeling he’ll be getting the local shop that has worked on it before try to fix it
Old Jun 3, 2025 | 05:58 PM
elPrez's Avatar
elPrez
Update!
So he just called me and we face-timed too.
He can get the key to turn to the unlock position and the forks have full movement BUT he can't remove the key unless its in the locked position. He only has the one key which is also the ignition key so he can't start the bike and ride it to the shop for them to look at it. I told him to keep spraying the inside and tap the area while wiggling the key but so far no luck.
Can he take the key somewhere to get a copy made or does he have to go through the dealer?
Old Jun 3, 2025 | 08:28 PM
Vernal's Avatar
Vernal
@elPrez
Any chance he can get at the connector to the key switch, unplug it and jump the R Battery to Accessory and Ignition? Or put a jumper between the battery fuse and the ignition fuse.
Old Jun 3, 2025 | 08:41 PM
im's Avatar
im
Did he use automatic transmission fluid as a lube for the lock as suggested?
Old school ATF can be very cheap and works amazing well at loosening things up.
It is reading like lock is very close to being "free".
Old Jun 3, 2025 | 08:49 PM
im's Avatar
im
E Bay has numerous key blanks available.
A locksmith should be able to copy key if presented with original key and a blank.
I would want lock unstuck before riding.
Old Jun 4, 2025 | 05:44 AM
Kenny94945's Avatar
Kenny94945
Get an extra/ spare key made ASAP !!!
Whatever it takes.
I can see Murphy's Law in action.
Yes, the rest of our co-members replies are valid advice.
Good luck.
Old Jun 7, 2025 | 05:51 PM
elPrez's Avatar
elPrez
Another update:
He got a spare key made, a whopping 8 bucks. Rode around his neighborhood slowly to make sure everything was ok and rode the short distance to the Indy shop he uses. They are ordering him a new lock cylinder and will replace everything when it comes in hopefully in a week or two. I assume he'll have to use 2 separate keys after that unless they can re-key the new lock to his old key. Either way, no big deal.
ptjohnson93
General Topics/Tech Tips
Jul 16, 2020 08:06 PM
Easyglide
2014-2024 Touring Models
90
Jul 13, 2017 12:17 PM
DrewBone
Oct 29, 2012 09:52 AM
Sturgeon
Jan 27, 2012 11:29 PM
King Rider
Sep 19, 2006 10:54 AM
