General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Hope this question wont be dismissed as stupid and I can get an answer. I have a 09 FXDL Low Rider with a stock 96 cubic inch engine. The owners manual says it holds 3 quarts oil with a filter change. I also checked Google and get the same answer. I put exactly 3 quarts in and changed the filter. I then took it for a 20 minute ride to warm the oil. After letting it set for about a minute I checked the oil level and it shows to be way over full. I checked it while on the jiffy stand by removing the cap, wiping it clean and reinserting the cap by screwing it back as per the owners manual. I did that 3 times and it still shows over full. I checked it again this morning while cold and got the same results. I'm at a quandry as to whether or not to drain some oil or ride it as it is. Any suggestions will be appreciated. Thanks in advance.
Did you drain the oil when the motor was warmed up, so all the oil is in the tank? If it's like an XL, you need the warm motor so as much oil as possible is in the tank, not drained back into the motor.
You can always take some out with a turkey baster or a cheap transfer pump from HF.
John
Never trust the service manual when it comes to capacities of oil, or primary, set the level by eye.
After you drain the oil (after running the engine for a while), refill to halfway up the stick, go for a ride, check it again, make a record of how much oil it actually took, now you will know how much to have on hand.
John
It has sump/pan same as the touring bikes, as it is a Dyna
Guess you did not read the oil change procedures in the owner's manual. The system capacity is three quarts, not all of it will drain out during an oil change, some stays within the engine oil passages.
From your owner's manual:
NOTICE
Do not overfill oil. Doing so can result in oil carryover to the air cleaner leading to equipment damage and/or equipment malfunction. (00190b)
I did read the owners manual and I don't see where it says anything about oil remaining in the passages. My mistake was blindly following the owners manual and adding the 3 quarts but I didn't want to risk damaging the engine starting it without the full 3 quarts in it. I'll follow the suggestion of using a turkey baster to withdraw some. Thanks for answering.
