General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
thats just a range, anywhere from 12 to 18 ft lbs. some like to use the high end, others the low end, others in the middle. whatever makes you confident that it's tight and done right.
My degreed mechanical engineering friend and biker/motorhead tells me that the lower value is the minimum necessary to prevent the fastener from loosening, and the maximum value is the upper limit before more applied force may cause damage. Solution--choose the midpoint between the minimum and maximum and torque to that value. Given the +/- inaccuracy of most torque wrenches, especially those that haven't been recently calibrated,the midpoint makes good practical sense as well.
It's common to indicate a range for fastener torque. Go to the mid-point between high & low and you'll be fine.
Then why in hell don't they give the spec as the mid-point instead of a range? I'm no mechanic but I have service manuals on most vehicles I've owned & never seen torque specs given as a range. Might be useful for an engineer but makes no sense to a backyard mechanic.
So why get pissy with me? I was just trying to answer your question.
If it bothers you that damn much throw the friggin manual out the window and be done with it!
Sorry, wasn't pissed at you, unless you're responsible for 'them' using a range instead of a number.
