Two Questions??
Old May 23, 2005 | 02:50 PM
AceArt's Avatar
AceArt
Default RE: Two Questions??
ORIGINAL: jcc/tx
RainEx marine is safe for plastics. At Wally World in the boat "stuff"..
Never heard of it before. Thanks for the heads-up. Art
Old Jun 6, 2005 | 01:18 PM
jtouchette's Avatar
jtouchette
Harley windshields are made of polycarbonate and have a thin polysiloxane coating. The ONLY thing that should be used is soap and water or i've found that driwash n guard is a harmless cleaner that works well too. Rain X is definately not good nor is ANY material which contains ANY solvent or amonia of ANY kind. I've worked with polycarbonate for many years and know what will kill it quick. Ref. aforementioned!
Old Jun 6, 2005 | 01:30 PM
HDF Tech's Avatar
HDF Tech
Your speedo problem is more than likely the pick up on the trans. They collect metal particles from the trans gears as they wear and in turn foul up the pickup being that they are magnetic pickups. You can clean and replace it but this only is a temporary fix, easier to just replace it and I found using redline shockproof heavy in the trans not only lubes the tranny better but just about eliminated this from happening again to the sensor. (very little wear to cause shavings) JMHO
2004hdflstf
Electrical/Lighting/Alarm
Jun 29, 2015 08:39 AM
leadman
Nov 1, 2011 09:03 AM
DENGUY
Sep 21, 2011 08:06 AM
sddyna
Sep 13, 2007 07:05 AM
jonhoffers
Aug 9, 2006 05:50 PM
