odometer
Old Nov 16, 2010 | 11:41 AM
Bob2243's Avatar
Bob2243
1st Gear
Default odometer
2002 Road King. Hi, On my odometer it either reads total miles or if I push the button it changes to trip miles and hold to reset trip miles. One time while working on the bike I happen to look at the odometer and it was flashing , don't remember what but as I tried to get it back to the miles, every time I pushed the button it started with a 1 and each time I pressed it it went to 2 then 3....and so on. Finally after turning the ignition on and off a few times it went back to its original total / trip miles. Does this odometer have other uses besides the two different mileages? I have no owners manual.
Question 2......On my security system, when I set it, if the bike is moved the lights ( turn signals ) start flashing, can or should the horn also be sounding?
  Thanks, Bob.
Old Nov 16, 2010 | 12:29 PM
UltraNutZ's Avatar
UltraNutZ
yes it does. it allows for the reading of various diagnostics codes pertaining to just about everything on your bike. Do a search on here to find diagnostic codes or look in your service manual. Will tell you more than probably ever wanted to know.
Old Nov 17, 2010 | 09:58 AM
Bob2243's Avatar
Bob2243
1st Gear
Thanks Ultra, I'll look those up.
Old Nov 26, 2010 | 07:05 PM
dickey's Avatar
dickey
No, the horn does not sound when the security lights flash, but there is a battery operated siren available that connects to your security system as an accessory option. It does not come with the bike's security system.
cajun1957a
Jan 23, 2019 02:11 PM
kcrick54
Feb 7, 2017 06:59 PM
damquick1
Apr 10, 2014 11:06 PM
bell927
Aug 23, 2012 12:26 PM
Bob2243
Welcome Area Only
22
Nov 24, 2010 01:22 PM
