Trying to get baffles out
Old May 23, 2012 | 09:42 AM
jmullins's Avatar
jmullins
4th Gear
Default Trying to get baffles out
Not sure where this belongs... I'm trying to get baffles out of some new Vance and Hines dual slash cut slip ons. Took the screws out and they will wiggle around some but won't even start out the back. Is there a trick I'm missing here or do I just need to man up lol
Old May 23, 2012 | 02:40 PM
jmullins's Avatar
jmullins
4th Gear
Come on guys I know SOMEONE here has done this
Old May 23, 2012 | 04:27 PM
1CdnHD's Avatar
1CdnHD
If they are just 'stuck', try firing up the bike, vibrations might help shake em' loose.
Old May 23, 2012 | 04:37 PM
Dawgtraxx's Avatar
Dawgtraxx
slide hammer with a hook, have the horizontal bar inside ?
Old May 23, 2012 | 05:04 PM
jmullins's Avatar
jmullins
4th Gear
No bar inside just a few holes toward the end of the baffle... Makes me think maybe there's a wrench or somethin that fits on there
Old May 23, 2012 | 05:07 PM
Dawgtraxx's Avatar
Dawgtraxx
May try a little pb blaster... Carbon probably built up
Old Oct 22, 2012 | 04:47 PM
NSCoyote's Avatar
NSCoyote
i find unless the pipe is bent or kinked from a lay down, warm the bike up then remove bolts fro mthe baffles and rev it a few times and they slide out soemtimes they get stuck just before popping out but then you can get em with your hands *wearign gloves* and yank on them
Old Oct 23, 2012 | 01:34 AM
HarleyGTP's Avatar
HarleyGTP
I agree! I had a problem with mine getting stuck just before popping out...a little muscle took care of it though.
Old Oct 23, 2012 | 04:54 AM
73oldsman's Avatar
73oldsman
To get mine out of my V&H Drag Pipes, I take a longer allen wrench and clamp it into a pair of vise grips and go into the pipes with the bent end. I then snag the nut that is welded to the inside of the baffle which the baffle retaining screw screws into and start working / pulling the baffle out. I've gotten mine out every time, after a little cussin and discussin! Good luck.
Wisenheimer16
General Topics/Tech Tips
Jul 7, 2019 04:43 PM
2007ELECTRICGLIDE
Sep 1, 2010 12:37 PM
jimmyroadking
May 20, 2008 08:28 PM
HDNY1
May 15, 2007 09:52 AM
mcro
Exhaust System Topics
Mar 4, 2007 04:57 PM
