high speed wobble
Old Nov 15, 2012 | 07:09 PM
johnny reb's Avatar
johnny reb
Default high speed wobble
my nightster has a slight shake wobble or just feels light in the front i feel it in the handle bars at 100 mph is this normal cause i am hauling *** or what i havent tried pushing on through 100 what do yall think
thanks reb
Old Nov 18, 2012 | 11:18 AM
95custmz's Avatar
95custmz
I've experienced this on wavey pavement. I had new balanced tires and ruled out neck bearing and ensured rear wheel spokes were tightened. I finally purchased steering stabilizer and bike rides smooth as glass.
Old Nov 18, 2012 | 11:21 AM
95custmz's Avatar
95custmz
See link:http://www.ebay.com/itm/Steering-Sta...af52cf&vxp=mtr
Old Nov 27, 2012 | 11:20 AM
grbrown's Avatar
grbrown
Wink
There a number of things that can cause that. Your bike needs to be in top shape, with good tyres at the correct pressure and with no odd wear patterns, alignment correct, steering bearings adjusted just right - you get the picture!
However the most likely thing on a bare bike is you the rider. You are probably gripping the bars tight against the blast! The simplest thing is to buy a pair of foam earplugs and try again. The reduced noise levels you are being subjected to should enable you to relax more. They are the cheapest tuning aid available!
Try it and report back.
Old Nov 28, 2012 | 12:45 AM
aquadave's Avatar
aquadave
well welcome to riding! Scary as hell huh? as GR said a lot of things can cause it and pretty much anybody that have done triplets has experienced it
johnny reb
Sep 26, 2023 06:55 AM
rysonn
Apr 26, 2023 11:14 AM
Rhettm
2014-2024 Touring Models
24
Jul 31, 2021 07:03 AM
snewlin
Oct 5, 2011 08:42 PM
gartec81
Sep 5, 2011 11:58 PM
