SERT Help Desparately Needed
Old Apr 27, 2007 | 11:52 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: SERT Help Desparately Needed
ORIGINAL: BTD
07 Heritage, thanks for your help. The crux of my situation seems to be that I can successfully load any/all of the OEM maps on the tuning file. I have on 07 RKC and if I tried to load an OEM MAP for a sportster, it looks like it would do that. With any of the "custom" maps, ***.MT6, it reverts to the stock MAP 159....MP6. When I load the file for a custom map, the new configurations are there and the map file shows BTD.MT6 but when I try to flash with the custom map, it reverts to HD MAP 159..MP6. I even tried to change the values for stock map 159... and saved it with like an 01 extension and no joy. The custom maps were e-mailed to me and I copied/pasted them into my tuning files directory. They are definately there and load up into the tuning file but I can't flash them. Any additional thoughts? Thanks for your help.
If you mean that you are expecting to see BTD as the cal ID when you "Get ecm info" after programming, that will never happen. The cal ID will always be the original# of the map followed by 3 digits. If you want to see if your maps are going into the ecm, click "EDIT" "PART NUMBER" and make it an 123 then click save. Save the map and flash the ECM. Then hit "GET ECM INFO" if you see XXXXXX.123 as the cal ID, you successfully loaded your map. The only thing I can make sense of from your description is that this is the case. The retrieved CAL ID is the PN entered in the above path, and you do not have the ability to change the Part Number portion of it, only the last 3 digits.
Old Apr 28, 2007 | 12:06 AM
BTD's Avatar
BTD
This makes sense. I'm actually trying to load the map you were kind enough to share with me. I will do as you suggest and hopefully that will do the trick. I really appreciate your help-many thanks.
Old Apr 28, 2007 | 12:39 AM
07heritage's Avatar
07heritage
6th Gear
BTD
I'm using the "H" CD, and the only files on it have .MT6 extensions. No .MP6 files. I suspect if I took an OEM file from my CD,named it with an .MP6 extension, then tried to download it to my ECMit would fail due to a bad checksum. I'm not familiar with .MP6 (dealer ?) files. Have you actually tried to flash the ECM with any of the .MT6 files off the CD?
As WVRDKING said, your file name can only have the LAST 3 DIGITS changed (not the filename extension), and theymust be digits (not characters). My guess is the file name (including the extension) iscalculated in the checksum, and the only part of the file name that is ignored are the last 3 digits of the name. The extension cannot be changed. Do you know the first part of the original file name from which your BTD file was created? If so, try naming your custom file using (OriginalFirstPartxxx.OriginalExtension), but changethe last 3 digits of OriginalFirstPartxxx to OriginalFirstPart001.OriginalExtension and installing that. That may bring joy.
Keep us posted!
'07
Old Apr 28, 2007 | 01:23 AM
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: 07heritage
BTD
Keep us posted!
'07
Notentirely true '07. AsI stated originally, the map "name" itself can be changed viaEDITING the file name and still flash the ECM without a problem.
Here is a pick of my map and file.
[IMG]local://upfiles/22226/0C5B985797304FFF952EF56D6301E3D0.jpg[/IMG]
Give the "custom" map a different descriptionor"name" so you can differentiate when flashing. This can be done by modifying the nameof the map vs. changing the last 3 numbersas previously stated. Either will work if done correctly..
Pic ofwhere to change the Part #:
[IMG]local://upfiles/22226/D55CD7C180A64A5EB1CADDA4ED0284C4.jpg[/IMG]
HOWEVER:
Just because you modify the name like I stated, which will work, when you look at the"ECM INFO" you will still see the name of the map as the program "knows it" and not what YOU named it. Modifying the part # will show up in the "ECM INFO" section though.
Here is an example of renaming the map, but NOT renaming the part number, and this still works as stated.
[IMG]local://upfiles/22226/7231F91813AE48B7B79E0366197C0815.jpg[/IMG]
Not that difficult, but certainly a challenge to troubleshoot over the internet when a glitch doesoccur.
Old Apr 28, 2007 | 01:49 AM
UltraKla$$ic
CONTINUATION:
LASTLY, I changed the PART # within the map for demonstrative purposes so you will see that it WILL show up in the "GET ECM INFO" box as stated so you can see for yourself to be able to confirm the "custom" map indeed will be the one that gets flashed into the ECM.
Pic here:
[IMG]local://upfiles/22226/9A7F73E0435A4EB1A4C23C43CE878EC7.jpg[/IMG]
Notice howchanging the PART # will show up in the"GET ECM INFO" box forconfirmation? BUT, you can just change the "name" of the file as well.
Clear as mud now?
Old Apr 28, 2007 | 02:00 AM
UltraKla$$ic
Now to clarify what changing the part # will look like in the "GET ECM INFO" box on a modified map with a name change also.
The PART # is what you will see changed, and I'm clear to think this is what YOU are looking for in conformation of a flash.
[IMG]local://upfiles/22226/B19EF636A03544D8968BB9DF5ED8FC00.jpg[/IMG]
[IMG]local://upfiles/22226/399EB0F4CBA24D64B7A1E658B75433D1.jpg[/IMG]
EXACT same map, different part #'s.
Hope this helps. Most typing I've done in 5 years.
Old Apr 28, 2007 | 07:52 PM
BTD's Avatar
BTD
SUCCESS!!!!!!!! Using the edit/save function and adding an extension e.g., -001 did the trick!! I flashed the new map and it showed 159xxx as the installed map and 159xxx-01 as the new flash. Many thanks to all of you for the invaluable help. Going to try the new map on a ride tomorrow. Thanks so much for all your assistance-I was pretty much DOA when I started and with all the help I'm learning lots.
tanglefootrgu
Mar 23, 2009 08:51 PM
lejj909
Sep 13, 2008 03:24 PM
killer.com
Aug 26, 2006 08:58 PM
clayman
Jul 23, 2006 01:07 AM
mtreager
Feb 8, 2006 12:57 AM
