103 build
Old Jun 21, 2015 | 04:43 PM
TLAugustine's Avatar
TLAugustine
Default 103 build
I am currently putting MVA heads Andrews 60 series chain drive cams and SE 11.1 comp piston On a Dyna. My question is this everybody wants to go to a larger throttle body and most replies say dont spend the money how about the stock throttle body with the high flo intake? Or what will work goid with my set up?
Old Jun 21, 2015 | 07:29 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Get a 50mm TB off of a touring bike and use that. No need to go any bigger on a 103".
Old Jun 21, 2015 | 07:57 PM
TLAugustine
Default 103 build
Thank You! Do you know what size is on a stock 103 it is a 2014? Dyna
Old Jun 22, 2015 | 10:33 AM
OldEnuf2NoBtr
It'll be a 46mm.
Old Jun 22, 2015 | 12:20 PM
TLAugustine
Thank You! I was told today on the HD tech line that it is a fifty on it? That sometime after 06 they were upgraded I forgot exactly when he said? I guess when I get it apart and it is a 46 I will then change it. I had asked the tech what was the diff between the se 50 in the catalog and he said it was the same as mine but for 06 because the 06 and prior was 46mm.
Old Jun 22, 2015 | 03:10 PM
OldEnuf2NoBtr
Dynas and Softails have 46's. The Touring models have 50's. What you were told on the HD tech line is wrong. Prior to 06 they were 44mm Delphi units.
Old Jun 23, 2015 | 08:35 AM
TLAugustine
Thank You! I knew something was off I kept getting to ma y conflicting answers!
Old Jun 23, 2015 | 11:01 PM
Ed Ramberger's Avatar
Ed Ramberger
Actually pre-06 was a 40mm bore. Many people mistakenly measured it out where the backing plate bolted on but the actual bore at the butterfly was 40mm.
cycler
Mar 15, 2019 10:39 PM
DonN
Jan 9, 2019 10:45 PM
abez
Engine Mechanical Topics
18
Feb 19, 2018 08:33 PM
InthewindMN
Oct 31, 2015 10:19 AM
razehog
May 11, 2007 02:47 AM
