ThunderMax Initialze Help..
Old May 2, 2007 | 06:47 PM
Puttnutt24's Avatar
Puttnutt24
Default ThunderMax Initialze Help..
This might sound like a stupid question but I need to ask...
Step 7 "Initialize the new ThunderMax ECM" It say's to cycle the key switch on and off three times for 30 seconds each cycle. Does this mean on and off then wait 30 seconds and then on and off and so worth. Or does it mean, on, wait 30 seconds then off and then wait 30 seconds and then on and then wait another 30 seconds, so worth and so worth? I believe the first case hold's true but I'd like to ask anyway, thx in advance, Rich
Old May 2, 2007 | 06:51 PM
davidwideglide06's Avatar
davidwideglide06
Default RE: ThunderMax Initialze Help..
The way I did it a few weeks ago after reading the instructions was to turn on 30 seconds and then turn off for 30 seconds. repeat two more times.
Old May 2, 2007 | 06:59 PM
PosseRider's Avatar
PosseRider
That is how I just did mine also. Instruction sheet was a little confusing. Works great, only dumb question, is the one you dont ask !!
Old May 2, 2007 | 07:32 PM
Puttnutt24's Avatar
Puttnutt24
Right on, thx guy's....Another thing, my unit came pre-programed from Zippers, it say's on my disc sleeve to skip step's 3-6, after I do step 7 (explained above) I do need to complete step's 8 thru 13 right? I can wrench with the best but my computer skill's lack and I hope I do this correctly. any other advice would be aprecaited, thx, Rich
Old May 3, 2007 | 05:30 AM
ICEMANNN's Avatar
ICEMANNN
ORIGINAL: Puttnutt24
you re better to double check which map and whick speedo code you got first because my TM was supposed to be pre-tuned by ZIPPERS and i have run a wrong map and a wrong speedo code for 300 miles till i check with my laptop ...
Old May 3, 2007 | 10:51 AM
djkolp's Avatar
djkolp
I was told my T-Max was going to be shipped with a map that fit my bike's configuration, but it was not. When I called them to ask why, they said they were swamped with orders for the tuner, and were shipping them with just a test map. Update your software with the latest maps, and install it yourself. Take your time, and read the manual before you jump in. If you ever have to disconnect the battery for whatever reason, pull the fuse for the ECM (T-Max) before you do. Also, anytime you change or update maps, or disconnect the battery, you need to do the re-initialization process all over again. Good luck.
DJK
Old May 5, 2007 | 09:32 AM
Spartan's Avatar
Spartan
From the off position: on/off, wait 30 sec. Repeat two more times.
Weeboy1
Apr 21, 2017 07:13 AM
justmike911
2014-2024 Touring Models
Feb 1, 2017 11:08 AM
nitrohound
Mar 11, 2012 07:21 AM
MDStbob
Apr 28, 2011 10:10 PM
riteway
Jun 4, 2008 11:26 PM
