Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I ask what map number that you are looking at for a reason. Different year bikes have different cylinder assignments on the map. The older bikes used to assign cylinder 1 as the rear, and later years cylinder one was the front. Post up the map number that your are intesinter in and we can discuss it will n particular.
m
m
Good point - Marelli and Delphi are flipped. Also, some head pipes don't flow the rear as much - example a stock bagger pipe when replaced with a good 2-1 really makes an increase in rear air flow.
these are the maps. im not exactly sure what numbers your referring to but im talking about the figures in the tables. lean in the rear rich in the front on almost all these maps..
