Where to install O2 sensors?
Old Aug 22, 2018 | 04:13 PM
Z's Avatar
Z
Default Where to install O2 sensors?
Hey folks, I'm about to install a data logging tool to record AFR, RPM, and throttle position for my 2000 Ultra which predates factory O2 sensors so I need to weld-in bungs for aftermarket sensors, and I could use some advise.
is there a certain distance downstream from the exhaust port that they should be placed in my Thunderheaders? Of course I'll be installing one for each cylinder and they'll be wide-band.
is there anything else I should pay attention to? Angle into the head pipe, things lile that?
Thanks in advance!
Old Aug 22, 2018 | 07:55 PM
marcodarq's Avatar
marcodarq
i was told by the guys at DJ that 6-9 inches from the port was a good distance, look at each pipe and visualize how much room you will have in the area that you first think about. you need room for the sensor and the wire harness, room to work with, remove for service/replacemnt(so that you dont have to remove the whole pipe). compare both this distance down the pipe and the area around the outside of the pipe so that you have a good angle.
m
Old Aug 23, 2018 | 11:23 AM
FLTRI17's Avatar
FLTRI17
Also the sensors should always be mounted in a way as to keep moisture/water from draining into the delicate zirconium piece inside . Always mount sensor tip downward into the pipe.
Bob
Old Aug 24, 2018 | 12:47 AM
Z's Avatar
Z
Thanks for the tips
Old Aug 24, 2018 | 10:00 AM
bustert's Avatar
bustert
pm me a place to send and i can shoot over to you a efi book that may be of help.
Old Aug 24, 2018 | 10:31 AM
Z's Avatar
Z
I'd appreciate that! Private message sent.
Old Aug 24, 2018 | 10:38 AM
bustert's Avatar
bustert
you might want to edit out the email address, send it through private message, will not show up to the world. just click on my name and it should show you the option. will send it.
Old Aug 24, 2018 | 11:04 AM
Z's Avatar
Z
Thanks. i thought about that immediately after posting here, and then edited and sent to you via PM.
izzyryder
Aug 12, 2024 08:06 PM
Rus103
Nov 17, 2022 06:19 AM
gtwalker1969
Apr 13, 2018 09:09 AM
mjlevi
2014-2024 Touring Models
Jun 29, 2015 06:11 PM
r0ckie
Exhaust System Topics
Oct 22, 2008 11:31 AM
