Electrical Issues
Old Apr 22, 2019 | 11:43 AM
oridgeley's Avatar
oridgeley
1st Gear
Originally Posted by jbarr1
Stock location would be under the right side cover just in front of the saddlebag. It’s possible that it has been replaced by an aftermarket unit which would be totally located in the timing cover (cam cover).
Thank you for your suggestions!
Old Apr 22, 2019 | 12:01 PM
oridgeley's Avatar
oridgeley
1st Gear
Bike had or has a Manganelli system....only used 2 yrs by Harley. Only suggestion to repair from dealerships are to sell it, or invest to install carbs.,
Anyone else having had this problem...what did you do?
Your input is greatly appreciated.
Old Apr 23, 2019 | 08:41 AM
bustert's Avatar
bustert
the pickup in the old breaker compartment (nose cone as some say) does fail over time and becomes heat sensitive and can cause stall issues. if the stock ignition was replaced with one under the cover, it to can fail with heat. i had an ultima that did the same. they have an over-current protection and will reset when the key is cycled.
but some of your issues point to something else.
power from batt > through 30 amp circuit breaker > starter post > ignition switch > system
if the circuit breaker heats up (bi-metal type) it will trip the power circuit, when it cools down, it will self reset and as long as the load causes it to heat up, it will cycle. these thing go bad over time so the first thing is to replace it, available at auto parts stores for a couple of bucks. it the contacts are burnt, no power to the ignition switch.
also, do not over look cable connections.
Old Apr 23, 2019 | 08:47 AM
attaboy15's Avatar
attaboy15
Welcome from Norcal
Old Apr 25, 2019 | 11:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by oridgeley
1995 Ultra Classic.
Currently there is no power from ignition switch to anything.
If there is no power coming out of the ignition switch, stop thinking about ignition module for now...
Let`s start here...
How did you determine that there was no power coming from the ignition switch?
Is there power going in to the ignition switch?
Old Apr 25, 2019 | 11:28 AM
jbarr1's Avatar
jbarr1
Bike had or has a Manganelli system....only used 2 yrs by Harley. .
So which is it? Does it have fuel injection or is it carbureted?
Dan has a good question.
Old Apr 25, 2019 | 11:39 AM
oridgeley's Avatar
oridgeley
1st Gear
It's fuel injected.
I'm not at the location of the bike...my son working on it in Fl. Also misstated was the year..it's a '98
Absolutely no indication of anything energizing, or lighting up....just as if there was a dead battery.
At any rate...upon further examining, tinkering/jiggling the wiring...we determined that the connector/connection for the cam position into the wiring harness weren't always making contact.
An planned extended ride on the weekend will tell ALL!!!!
Does this make sense to you????
Bcreech1970
Welcome Area Only
23
Mar 1, 2019 01:10 PM
harleyrider06010
Welcome Area Only
15
Dec 20, 2014 01:21 AM
dex0807
EVO
Sep 29, 2008 02:15 PM
traderrei
Welcome Area Only
Oct 1, 2006 11:47 PM
Alia1200
General Topics/Tech Tips
Jun 26, 2005 07:17 PM
